help-replacing cam seal
Old Jan 25, 2002 | 06:32 AM
four27's Avatar
Default help-replacing cam seal
Seems you take the valve cover off and then the upper cam bearing cap and pull the rubber seal out. Is this correct and will I need any new seals or gaskets besides the cam seal. Any landmines I should be aware of ?
Old Jan 25, 2002 | 06:35 AM
rainforest's Avatar
Default Re: help-replacing cam seal (four27)
nope you are right you will need some gaset sealer(hondabond) also and its the cam cap hondas dont use bearings on the cams.
Old Jan 25, 2002 | 09:15 AM
EE_Chris's Avatar
Default Re: help-replacing cam seal (rainforest)
If your valve cover gasket has a few miles on it, might as well replace that too....its only like $6 from HParts, and of course you'll need some Honda-Bond to seal everything back up.
Old Jan 25, 2002 | 09:25 AM
Notorious BAE's Avatar
Could be of some use for you:
http://importnut.net/STRseal.htm
Old Jan 25, 2002 | 02:54 PM
four27's Avatar
Default Re: help-replacing cam seal (Notorious BAE)
As usual you guys are awsome
nicko360
Jan 16, 2007 07:56 AM
TheWalrus
Jan 30, 2006 05:47 AM
StupidSlowRSX
Jun 2, 2004 10:30 AM
blackdude
Mar 17, 2004 08:55 AM
cvc323
Nov 3, 2003 03:37 PM
