Weak Clutch Already????
Old Oct 27, 2008 | 05:18 AM
otakuzero81's Avatar
Default Weak Clutch Already????
Ohh man is my clutch dying ??
So as of three days ago when I go to push my clutch it feels loose!Its not an advanced set up. Pushing it midway I get this "whirring" noise. Then when I fully engage the clutch to the floor I'm barely getting the shift to first. Second and so on engage fine.
Do I have a loose pedal or......?? I've had shift linkage issue's since obtaining ownership, due to a faulty pin in the assembly but, never the weak clutch symptom.
HERE WE GO!
Old Oct 27, 2008 | 06:42 AM
hatchling37's Avatar
Default Re: Weak Clutch Already???? (otakuzero81)
Sounds like your clutch is toast.
Old Oct 27, 2008 | 08:18 AM
93hatched_projekt's Avatar
Default Re: Weak Clutch Already???? (hatchling37)
You checked your clutch fluid right? Try bleeding your slave cylinder and see if you get pedal pressure.
Old Oct 27, 2008 | 11:10 AM
Where's the slave cyl? Didn't try that but will add it to inquiry checklist.
Thanks for quick response too!
Old Oct 27, 2008 | 11:11 AM
Default Re: Weak Clutch Already???? (93hatched_projekt)
Yeah dude that's what I think too
Old Oct 27, 2008 | 04:46 PM
It's the valve on your tranny in front of your radiator. It may be leaking , check your fluids and see if it's low.
Old Oct 28, 2008 | 05:09 AM
cool will do. If low just fill with trans fluid?
Old Oct 28, 2008 | 06:09 AM
Default Re: (otakuzero81)
Your scarring me (everyone must learn tho), you dont put tranny fluid in clutch resovoir. Use dot 3 brake fluid for both brake and clutch resovoir. Tranny fluid is only for your gears.
Old Oct 28, 2008 | 06:16 AM
haha--yeah that's me still learnin internals.
I can handle the wheel tho.
Old Oct 28, 2008 | 06:47 AM
Yeah, definitely DO NOT put ATF in your clutch reservoir. If you mix petroleum fluid with brake fluid, it destroys all the rubber seals in the system, thus having to replace master cylinder, slave cylinder and possibly even the brake hose.
Old Nov 5, 2008 | 06:23 PM
Hello again
For the record the car is alright-went ahead and got the stock stage one clutch put in.
Gears actually catch way better now. Still need more work on wiring and some stock internals.
thanks for all the input people!
havikprelude
Transmission & Drivetrain
Jan 20, 2010 09:32 AM
Sinner
Apr 27, 2006 10:44 AM
jack1
Nov 15, 2005 06:46 PM
Jack Black
Feb 18, 2005 11:30 AM
tianporn
Nov 5, 2004 12:18 PM
