We got some weird codes after H22 swap
I am working on a buddies car and after installing the JDM H22 into a 94 Teg we got codes 3 and 7. They are the Map and TPS sensor. We are for sure that they are hooked up correctly( With them being the same plugs; they are not hooked up backwards!!). We are using the B-series Map and TPS sensor which i have read is ok. The weird thing is that he does not have the O2 sensor hooked up and it isn't throwing a code for that. And the EGR isn't hooked up, and we are not throwing a code for that either. We are using the P13 w/ the B-series wiring harness changed for the H22. Help would be appreciated.
Thanks
Thanks
Throttle body had to be cleaned and that fixed the map sensor code. The TPS was not installed correctly.... A friend just bolted it up and didn't realize that the little finger on the TPS Sensor had to in between the two metal points in the area where the sensor goes onto the TB.
maybe this can help someone else-
Corey
Corey
djnikko
Jan 13, 2010 07:23 PM
