Water pump(overheating motor)
Old Jan 29, 2002 | 08:53 PM
b18c1civic95's Avatar
Default WatEr pumP(overheating motor)
ok.....im really really dumb. i swapped a gsr motor into my hatch and when i was doing it i saw this pump with a pulley im like heyyyyy ill just leave that off thinking its a damn power steering pump which i dont need and could free up some horses but im getting a feeling that its the water pump. CAN ANYONE EXPLAIN WHERE THE HOSE WOULD GO FROM IT THOUGH?? the motor was doin good and the day was goin good until i saw my temp gauge about to start another round lol.
Old Jan 29, 2002 | 09:10 PM
D-SPEED's Avatar
Default Re: WatEr pumP(overheating motor) (b18c1civic95)
the water pump is on the block, driven off the timing belt.
Old Jan 30, 2002 | 04:32 AM
Sonic's Avatar
Default Re: Water pump(overheating motor) (D-SPEED)
Your motor wouldn't run with no water pump, the timing belt wouldn't fit.
If the pulley wasin the back, it's the alternator. If the pully is on something on the front n top, it's the power steering. If the pulley is on the bottom of the front, it's the A/C.
I dont think that taking off one of these was the cause...is your cooling fan working properly? Perhaps your radiator isn't up to the task of cooling the larger motor.
Old Jan 30, 2002 | 07:22 PM
Default Re: Water pump(overheating motor) (Sonic)
yeah it was the power steering pump but i guess i was desperate for an explanation... uhm i put a new thermostat in today and it wasnt that. and i watched after it warmed up to 1/3 and no fan!! then at half way point still no fan!! so i guess i dont have to think about whats going on very much huh lol. but i cant see my fan making much of a difference. i understand that i need to most likely get a teg one maybe but ive seen a few people running dohc's in their hBs' and not having this problem. but i will get my fan taken care of friday.
Old Feb 1, 2002 | 11:10 AM
daver's Avatar
Default Re: Water pump(overheating motor) (b18c1civic95)
try connecting yor fan straight to the battery to eliminate it. Or jump the thermosensor switch in the back of the block (or is it there on a gsr), to see if its the switch.
d
ACCORDingly94
Engine Machining & Assembly
Jul 27, 2015 12:55 AM
92civicfreak
Jun 1, 2007 02:26 PM
RussHondaCRXVtec
Aug 20, 2003 02:42 PM
snoop_bealybob
Mar 26, 2003 06:04 PM
B18C
Nov 19, 2001 02:05 PM
