Water bar Question
Old Aug 18, 2002 | 09:11 AM
Boost2NA's Avatar
Default Water bar Question
Yesterday we were swapping all my parts over from my b16 block to my b18 block. On the water bar (bar on back of block) we couldnt get it to go into the b18 block. it almost looks like the rubber o-rings got stretched some how. I talked to one of my boys and he says the rings are suppose to be a little bit bigger than the bar too ensure a tight seal. i just wanted to clarify this before I go and start cramming the o-rings in there. Thanks any info will be helpful
Old Aug 18, 2002 | 09:38 AM
92sleepR's Avatar
New User
Default Re: Water bar Question (Boosted99Si)
Its a bit of a tight fit but if you lube them up a little you should be able to easily wiggle it into the housing at the water pump outlet. If you really have to force it something is wrong (and isn't that the case for most things ? )
Mike
hmt_eg
Feb 24, 2010 01:29 AM
Inextricabledrvr
Paint and Body
Oct 24, 2007 06:23 PM
philkehn
Oct 19, 2006 02:04 PM
mr devious illusions
10
Jun 9, 2006 01:26 PM
youngkow
Nov 22, 2003 08:38 PM
