Washer Trick Bolt Question
Old Oct 19, 2003 | 06:56 PM
JamesQ's Avatar
Default Washer Trick Bolt Question
Was wondering are power tools necessary to remove the bolts to install the washers (for rear camber adjustment) or would normal socket wrench do the job?
Hope this is the corrct forum for my question
Modified by JamesQ at 6:41 AM 10/20/2003
Old Oct 19, 2003 | 07:00 PM
spaceman's Avatar
Default Re: Washer Trick Bolt Question (JamesQ)
are you joking?.what are you talking about?
Old Oct 19, 2003 | 07:06 PM
timmy8151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JamesQ &raquo;</TD></TR><TR><TD CLASS="quote">Was wondering are power tools necessary to remove the bolts to install the washers or would normal socket wrench do the job?
Hope this is the corrct forum for my question</TD></TR></TABLE>
Are you talking about the bolts to adjust rear camber?
If you are, then all you need is a ratchet, extension and 14mm socket.
Old Oct 19, 2003 | 09:41 PM
JamesQ's Avatar
Default Re: Washer Trick Bolt Question (timmy8151)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">
If you are, then all you need is a ratchet, extension and 14mm socket.</TD></TR></TABLE>
Thanks, exactly the info I needed. Sorry I didnt make it clear in my first post that this was for rear camber adjustment
Old Oct 19, 2003 | 09:44 PM
chad174's Avatar
where do you place the washers? someone please fill me in on this.
Old Oct 19, 2003 | 09:52 PM
JamesQ's Avatar
Default Re: Washer Trick Bolt Question (chad174)
http://home.earthlink.net/~civ....html
Old Oct 19, 2003 | 09:59 PM
MrIllegalX's Avatar
I did it on my rears. Worked great. I actually orderd a kit from Progess, and that's what they sent me. Cheapasses.
Old Oct 19, 2003 | 10:19 PM
JamesQ's Avatar
Default Re: (MrIllegalX)
Yea i've seen there rear camber kit picture on some site before. Looks just like washers and screws
Old Oct 20, 2003 | 11:24 AM
IN VTEC's Avatar
Kinda reminds me of a friend who used a 1/2" drive impact wrench to remove the oil drain bolt on his mom's Volvo. It ended up being a 1/16 scaled Exxon Valdez in the garage.
The bolts are probably 10mm thread size. Go to the hardware store and pick up some hardened M10 washers.
RockWolf
Jul 31, 2007 10:45 AM
lil k
May 19, 2003 12:22 AM
cracker099
Sep 8, 2002 10:58 PM
Fuster_Cluck
Jul 10, 2002 10:35 AM
Lei Siew Long
Jul 8, 2002 06:11 PM
