washer question...
Old Jan 5, 2003 | 02:54 PM
96 SOHC VTEC's Avatar
Default washer question...
Is it bad to put washers in the rear to correct the camber, and then take them out again for HPDE's? I would like to run more negative camber at the track, but then put them in again for the street? Would this mean I would constantly have to get an alignment? If so, how bad is -2.0 and -2.4 camber in the rear with no weight over it? Will they wear quickly?
Back seat is removed.
[Modified by 96 SOHC VTEC, 11:55 PM 1/5/2003]
Old Jan 5, 2003 | 02:56 PM
junb16's Avatar
Default Re: washer question... (96 SOHC VTEC)
my understanding is that anything you do to your camber is going to need an alignment. i did the washer trick and got an alignment, its good enough for me.
Old Jan 5, 2003 | 05:44 PM
Default Re: washer question... (junb16)
Anybody else?
B_Swapped93
May 29, 2014 05:41 AM
sk8shorty012
23
Nov 14, 2006 10:59 AM
EK k kay
Suspension & Brakes
Aug 27, 2006 10:10 PM
alfaaay
Mar 21, 2003 06:30 PM
Chris N
Oct 18, 2002 08:04 AM
