Can't put car into gear. HELP!
Old Jan 5, 2003 | 01:59 PM
djtony5's Avatar
Default Can't put car into gear. HELP!
Hey guys I'm in serious problem. My car have been acting up on me lately and now I can't even put it into any gear. First off I don't know where the problem is located at..Either the Clutch,Synchro or whatever. But when I could drive the car, it hard for me to shift gear..It like I have to use force to shift, also I could just pull the gear out into neutral without stepping on the clutch. I know it not my tranny fluid because I just recently change it.The clutch..well if it did run out on me then the rpm would rise if I were to cruise on 5th gear and smash but it didn't. I have no clue so help me out! thanks you
Old Jan 5, 2003 | 02:15 PM
b19coupe's Avatar
Default Re: Can't put car into gear. HELP! (djtony5)
Sounds like a broken clutch disk spring retainer.
Old Jan 5, 2003 | 02:17 PM
djtony5's Avatar
Default Re: Can't put car into gear. HELP! (b19coupe)
Hey..If it is that then I would have to get a new clutch?
anywayz the problem is weird because sometime I could put the car in gear and sometime not when starting the car..
Old Jan 5, 2003 | 02:31 PM
tilt's Avatar
Old Jan 5, 2003 | 02:42 PM
djtony5's Avatar
Default Re: Can't put car into gear. HELP! (tilt)
Hehe does that mean time for a new clutch? If so, which aftermarket cluch should I go for.
Old Jan 5, 2003 | 06:43 PM
myhatchrips's Avatar
just go with a HYPERCLUTCH PERFORMANCE KIT. i have a street version setup and it still grabs hard also maintains daily drivability. http://www.inlinefour.com
John 07
Sep 11, 2012 07:18 PM
Nar0ng
Sep 3, 2007 04:32 AM
silent-chris
Honda S2000
Sep 17, 2006 09:00 PM
ChrisSpade
Apr 22, 2006 10:16 PM
canadaitr
Mar 24, 2003 07:17 PM
