warped head?
Old Feb 17, 2008 | 06:30 PM
kidd3121's Avatar
Default warped head?
is there any kind of test that you can do to see if you have a warped head without having to take off the head? thanks
Old Feb 17, 2008 | 08:10 PM
wed3k's Avatar
a blown headgasket test?
Old Feb 17, 2008 | 11:26 PM
ddd4114's Avatar
Default Re: warped head? (kidd3121)
No.
Old Feb 17, 2008 | 11:45 PM
JerkDC2's Avatar
Default Re: warped head? (ddd4114)
a warp head causes you to blow out white smoke correct?
Old Feb 18, 2008 | 12:11 AM
ddd4114's Avatar
Default Re: warped head? (JerkDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JerkDC2 &raquo;</TD></TR><TR><TD CLASS="quote">a warp head causes you to blow out white smoke correct? </TD></TR></TABLE>
It depends how badly it's warped. If the total deflection is 0.001", the head gasket should seal fine. If it's more like 0.100", you're going to have problems.
Old Feb 18, 2008 | 12:34 PM
kidd3121's Avatar
ive heard that you can take your coolant to a radiator shop and have it tested for hydrocarbon? and that will determine if you have a bad hg
Old Feb 18, 2008 | 01:20 PM
GhostAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidd3121 &raquo;</TD></TR><TR><TD CLASS="quote">is there any kind of test that you can do to see if you have a warped head without having to take off the head? thanks</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 &raquo;</TD></TR><TR><TD CLASS="quote">No.</TD></TR></TABLE>
A hydocarbon test will only prove that maybe your head gasket could be blown or you have a blown cylinder wall and exhaust gases are mixing with your coolant. There are quicker ways to test for that.
What are you really looking for hear? Why do you think your head is warped? Are you burning coolant after you just replaced a HG or something. Why do you want to test if your head is warped? Not that it really matters because as far as I know most shops don't carry an xray that can scan an engine and look inside for warped surfaces.
cdizzle
17
Jun 30, 2007 11:48 PM
diagnostic
Jan 28, 2007 04:06 PM
quick87crxsi
Nov 26, 2006 05:42 PM
JDMlyfestyle
10
Nov 14, 2004 05:42 AM
petrv
Jul 11, 2003 11:53 AM
