vtec and safe mode help!!
Old Nov 21, 2007 | 05:28 PM
boosted_rex_bloNby's Avatar
Default vtec and safe mode help!!
i have a b16a that stays and safe mode (rev limitor @ 7200rpm) and wont hit vtec. i am am only getting one code. It is the tdc sensor. does anyone know if that will keep you from hitting vtec and keep your engine from running right?
thanks much
Old Nov 23, 2007 | 02:28 AM
gibsanez's Avatar
Default Re: vtec and safe mode help!! (boosted_rex_bloNby)
CEL's will not let you crossover into VTEC.
Old Dec 5, 2007 | 10:27 PM
Default Re: vtec and safe mode help!! (gibsanez)
could a new distrubuiter be the answer to y its tripping off the top dead center sensor?
Old Dec 6, 2007 | 12:58 PM
JasonST's Avatar
What year of engine/car do u have. The TDC will be either in ur engine block or in the dizzy depending.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">CEL's will not let you crossover into VTEC. </TD></TR></TABLE> Nope, not all the time, only a few cel's will not let vtec engage.
Old Dec 6, 2007 | 05:04 PM
Default Re: vtec and safe mode help!! (JasonST)
its obd0 so 88 to 91. i did the swap and have been driving it around for four months now on safe mode and don't wanna spend two hundred dollars on a dizzy if its not going to fix the problem. thanks for the help
Old Dec 6, 2007 | 07:01 PM
JasonST's Avatar
unfortunatly the only way i'm away of fixing the TDC cel is ur ganna have to replace the whole distributor. Or maybe just find a shell and swap the internal parts over.
Old Dec 6, 2007 | 10:54 PM
ok cool i guess that would be my answer then. if you were going to spend the money would you just convert it to obd1 instead of buying an obd0 dizzy?? your video is hilarious!!! thanks for the help again
Old Dec 7, 2007 | 12:18 PM
JasonST's Avatar
If the car and engine run fine other then the TDC problem I wouldn't worry about converting it it to obd1, just find a good deal on a new or good used working distributor and ur problem should be solved. Make sure to adjust the timing when u put the new distributor on. Good luck
Old Dec 8, 2007 | 09:10 AM
the only problem is its a jdm b16 and i have no idea what dizzy to get for it? would you happen to know?
Old Dec 8, 2007 | 10:06 AM
JasonST's Avatar
Yeah look on the distributor, it should say TD- then 2 numbers I believe. It might be the same as the US version, or it may not i'm not sure about the b16. I know for my h22 the jdm dizzy has an internal coil, and the us version has an external coil. I got mine from a race shop thought it was like $300.
Old Dec 20, 2007 | 05:09 PM
i replaced the distrubuiter and it still is throwing the tdc sensor. so now i don't know what or how to trouble shoot the problem.
GSRBrent
Nov 4, 2007 01:20 AM
la_mente_maestra_13
Honda Civic (2001 - 2005)
23
Aug 29, 2007 07:31 PM
poppypizza
Sep 2, 2006 03:41 PM
lubmyinteg
Honda S2000
Feb 3, 2006 12:56 PM
SixguN
14
Mar 11, 2005 11:45 PM
