vtec problems
Old Aug 19, 2009 | 01:06 PM
monster_ls/vtec's Avatar
Default vtec problems
i have a built ls/v ctr pistons skunk 2 cams cam gears stock bore ok so heres the problem ever time i hit v the check light comes on amd when i scan it its a code 3 map sensor. so i replaced it 4 different times and still same thing some one help!!!
Old Aug 20, 2009 | 12:09 AM
EJ1B18c's Avatar
Default Re: vtec problems
Try looking at the map sensor wiring back to the ecu.
Old Aug 20, 2009 | 01:31 PM
thats wat i thought to but its fine do u think it could be the ecu? the way it was tuned maby
Old Aug 21, 2009 | 05:10 AM
EJ1B18c's Avatar
possibly, i dont know a lot about tuning, but on my s300 software you pick/choose what map sensor you are using under the replacement map sensor window. possibly your map has the wrong sensor type selected.
baulum
Apr 13, 2008 10:18 PM
GearheadzAuto
Nov 15, 2007 08:05 AM
lysergican
Jul 12, 2002 04:29 AM
