vtec pressure code
Old May 3, 2011 | 01:19 PM
b16_swap's Avatar
Default vtec pressure code
I have a 00 civic si and did a jdm b18c swap in it. the swap was done well and i am using a00 civic si wiring harness. i am also using a obd2a ecu that is suppose to be a type r ecu.
the only code im throwing is the vtec pressure code. I dont know what is wrong. I also swapped the vtec pressure switch from the usdm vtec solenoid and put it on the jdm one. still throwing that code. any suggestions??
Old May 3, 2011 | 01:50 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: vtec pressure code
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
Old May 3, 2011 | 07:46 PM
b16_swap's Avatar
that thread is nice but i havent checked my vtec oil filter but im sure its fine.. thrers no oil leaking from the solenoid
Old May 3, 2011 | 08:17 PM
carbon_si's Avatar
atleast you got a cel. funny i got the same car and the same swap only difference is im running a chipped obd1 ecu and my vtec just isnt working. even changed the oil and filter and checked the solenoid filter. im stumped
Old May 4, 2011 | 08:52 AM
b16_swap's Avatar
I am pretty sure if u just buy a stock obd1 ecu, u will be fine.. maybe thats what i need to do ?
Old May 4, 2011 | 10:12 AM
TheAsian's Avatar
Somebody correct me if I'm wrong but jdm b series don't have vtec oil pressure switches.
Is the ecu your using a us spec itr ecu?
Old May 4, 2011 | 12:29 PM
Technical Hero
Old May 4, 2011 | 03:10 PM
b16_swap's Avatar
okay so i ran my code today and it turns out it wasnt the vtec pressure code.. its throwing a knock sensor code.
I checked to see if the knock sensor plug *located behind the intake manifold above the oil filter plug and it is connected.. I cna click the plug in and evertyhign? should i swap oput the knock sensor from my hydrolocked b16?
Old May 6, 2011 | 08:51 AM
b16_swap's Avatar
bump.. will knock sensor code go away after replacing the sensor?
i dont here any knocks or pings in the motor, runs fine, hits vtec real smooth and idk its just a clean lookin swap.
b16_swap
May 3, 2011 07:47 PM
Brandoff
Sep 1, 2008 03:15 PM
JAYDEEM95
Jul 7, 2006 09:11 AM
BigBlockCRX
Jul 29, 2003 06:14 AM
BigBlockCRX
Jul 21, 2003 06:55 AM
