VTEC oil pressure switch
Old Dec 12, 2002 | 09:17 PM
B16A1-EF9's Avatar
Default VTEC oil pressure switch
Since it's called a switch I assume it works as on/off and not a signal of how much pressure is going through it right?
Anyway, my question is, at what pressure does it turn on at or turn off? The reason I ask is I would like to setup a warning light to my switch. I don't really need the switch anymore since I'm going standalone but I think it would be added insurance to have a warning oil pressure light for the VTEC since I am going LS/VTEC. Anyway, at what pressure does VTEC require to work, what pressure does the switch work on and what pressure is the minimum for VTEC to operate safely?
Sorry for the long post guys!
Old Dec 13, 2002 | 07:00 AM
B16A1-EF9's Avatar
Default Re: VTEC oil pressure switch (B16A1-EF9)
bump
Old Dec 13, 2002 | 07:23 AM
Spade's Avatar
It is RPM activated by the ECU.
Without it your ECU will not allow you to enguage VTEC.
Old Dec 13, 2002 | 09:30 AM
B16A1-EF9's Avatar
Default Re: VTEC oil pressure switch (Spade)
I know how VTEC works...I do conversions myself. The VTEC oil pressure switch must send a signal to the ECU that tells it that there is enough pressure for VTEC to activate, right? OK, what I need to know is at what PSI does it turn on and off at so I can hook-up a light to it.
Old Dec 13, 2002 | 09:31 AM
Spade's Avatar
That pressure switch is unreliable. You have to be short about 4 quarts for it to not work.
Old Dec 13, 2002 | 03:16 PM
Civichatch2k's Avatar
it engages with the ecu and it is a signal no ecu-no vtec.
Old Dec 13, 2002 | 03:51 PM
Jaker's Avatar
The switch does not stop Vtec from activating. The way it works is: the Vtec turns on, and the ECU looks for oil pressure at the switch. If the pressure is not there, the ECU turns off Vtec and gives you the dreaded code 22. If you look closely at the internals of the Vtec solenoid, you'll see that the pressurised oil from your block goes through the solenoid portion, before it reaches the pressure switch.
Sorry, I don't know what pressure (psi) it is looking for.
Tunerguy1989
May 5, 2009 02:54 PM
raidacaipo
May 10, 2008 09:36 PM
Takumi Fujiwara
Jul 23, 2006 09:18 PM
blueeg
Apr 25, 2006 11:16 AM
wannagofaster
Sep 4, 2004 03:25 PM
