vtec oil pressure!!!
Old Aug 18, 2004 | 07:50 PM
EG6AAARRR!!!'s Avatar
Default vtec oil pressure!!!
i just got my car running and i notice that my vtec is not kickin...i have a 1st gen b16a...the wires are all wired up right...now my question is how can i check the oil pressure to make sure that it is high enough for vtec...should i let the car run for a min then check it....where should i look and what should i check to get my vtec working right....??
Old Aug 18, 2004 | 09:46 PM
bigTom's Avatar
Default Re: vtec oil pressure!!! (88g1tegls)
oh the front of the head... right in front of the vtec solenoid is a bolt (plug) with a 10mm head on it... its on the upper portion of the head... i forgot the exact thread size now... u need to get any pressure guage (for oil) with an adapter to screw in there... with the motor running (idleing) u should only see a couple psi (~5psi)... then run a wire from the battery positive to the wire on the solenoid. ull here a click... the oil pressure should jump up... i forgot the psi it should be at but if i remember correctly it should be around 60... someone correct me if im wrong... pretty much there should be a big jump in oil pressure
Old Aug 19, 2004 | 04:17 AM
Default Re: vtec oil pressure!!! (ek9t)
thanks man...ill check up on that today
Old Aug 19, 2004 | 08:51 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9t &raquo;</TD></TR><TR><TD CLASS="quote">with the motor running (idleing) u should only see a couple psi (~5psi)... then run a wire from the battery positive to the wire on the solenoid. ull here a click... the oil pressure should jump up... i forgot the psi it should be at but if i remember correctly it should be around 60... someone correct me if im wrong... </TD></TR></TABLE>
60 psi at idle? I don't think so.
Old Aug 20, 2004 | 04:19 AM
Default Re: vtec oil pressure!!! (Chiovnidca)
ok so when i check my oil pressure..and it doesnt go up after i put a direct connection to the silonoid...what does that mean i should do...if the silonoid is good and its all wired up right and there is no pressure what should i do...new oil pump?...
Old Aug 21, 2004 | 06:13 AM
bump
Old Aug 21, 2004 | 06:41 AM
mmuller's Avatar
Mad Scientist
the vtec oil pressure port should have no pressure untill the sol. is activated, then it should read 50+ psi.
so hold the engine anything higher than 3k rpms and you should read at least 50 psi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88g1tegls &raquo;</TD></TR><TR><TD CLASS="quote">ok so when i check my oil pressure..and it doesnt go up after i put a direct connection to the silonoid...what does that mean i should do...if the silonoid is good and its all wired up right and there is no pressure what should i do...new oil pump?...</TD></TR></TABLE>
you checked it? what pressure are you getting?
Old Aug 21, 2004 | 08:28 PM
Default Re: vtec oil pressure!!! (mmuller)
i havent checked it yet....i was about to check it today but i couldnt find the right adapter to fit the gauge in..(10mm)
Old Aug 22, 2004 | 02:39 AM
anothersickhatch's Avatar
i know this sounds like a small thing, but do you have enough oil in your motor? i havent read anything that said you checked your oil so i dont know if you have.
its the simplest and first thing you shouldve checked.
Old Aug 22, 2004 | 06:12 AM
Default Re: vtec oil pressure!!! (anothersickhatch)
yes i just changed the oil friday....didnt work before...didnt work after...
Old Oct 8, 2004 | 01:41 AM
ViXoN Hatch94's Avatar
ey im having the same problem with my B16a in my hatch... how did you fix your oil pressure problem?? new oil pump or wat?
prime-R
26
Jun 4, 2011 11:32 AM
tonymwc
Mar 23, 2008 06:45 AM
eat_sleep_ej1
12
Dec 1, 2007 04:43 AM
shifty35
Apr 3, 2006 08:47 PM
zdr262
Oct 23, 2001 01:51 PM
