Vtec not working. HELP!
Old Feb 22, 2004 | 12:04 PM
HybriDNA's Avatar
Default Vtec not working. HELP!
Modified by HybriDNA at 11:31 PM 2/23/2004
Old Feb 22, 2004 | 12:12 PM
mmuller's Avatar
Mad Scientist
Default Re: Vtec not working. HELP! (HybriDNA)
so.. does the solenoid work?
If the solenoid gets power and engages, then is an oil problem.
are you getting oil pressure to the solenoid?check that
what did you do the engine?
did you mess with the oil control thingy on the block?
What about oil control pins on the rocker arm shafts?
Old Feb 22, 2004 | 12:25 PM
HybriDNA's Avatar
Default Re: Vtec not working. HELP! (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">so.. does the solenoid work?
What about oil control pins on the rocker arm shafts?</TD></TR></TABLE>
The vtec soleniod is not working this is the second one changed out. I don't know if im getting oil pressure to the solenoid. THe engine is a b18a1 with a 95 gsr head. BLock is rebuilt with Pr3 pistons. I did take out the oil pressure sensor to tap in the OIL line to the head and i "T" it off to the Oil pressure sensor. Im not sure about the oil control pins on the rocker arm shafts.. It came off a running car.. Never touched them.
Old Feb 22, 2004 | 10:36 PM
DisOnesAPlaya's Avatar
I'm going thur the same problems. keep me posted on updated when u fixed yours.. someone help this guy.. i
Old Feb 23, 2004 | 03:56 AM
rjardy's Avatar
Default Re: Vtec not working. HELP! (DisOnesAPlaya)
Is it getting the correct amount of voltage?
refer to HELMS for voltage specs.
Rob
Old Feb 23, 2004 | 01:24 PM
HybriDNA's Avatar
Default Re: Vtec not working. HELP! (rjardy)
Well im stumped.. Looks like imma have to spend money having someone fix it.
Old Feb 23, 2004 | 07:10 PM
deagleEF8's Avatar
hey HYBRIDNA, wheres my money or my block? you can post on your own threads, but cant email me back about my money or block!
https://honda-tech.com/zerothread?id=775994
AL ASPIRATED
Apr 18, 2015 03:29 PM
Tushner
Jun 3, 2004 09:20 AM
kerby116
Mar 11, 2004 01:06 PM
tgreaves
Nov 7, 2003 07:42 AM
KS-R
Jan 17, 2002 01:44 AM
