Vtec not working?
Old Mar 19, 2015 | 04:02 PM
Sparcofreak's Avatar
Default Vtec not working?
I just bought a 99 civic ex and the block says d16y8. So in theory it should be a vtec engine. But he said it had head work done to it and I don't feel vtec at all. Is it something that could just be unplugged or the vtec solenoid be bad or something. Where should I start? (First Honda I've ever owned so please be nice)
Old Mar 19, 2015 | 06:19 PM
2point1's Avatar
Default Re: Vtec not working?
Do you have a check engine light on?
Do you have a VTec ecu?
Vtec in a d series is not like VTec in a b series.
Old Mar 20, 2015 | 02:21 AM
HondaPartsHero's Avatar
Technical Hero
Exactly as said above. Also what does it rev out to? If it goes out to 7200 your VTEC is working.
Old Mar 20, 2015 | 05:51 AM
No check engine lights.
Revs to a hair over 6,000 rpm
Old Mar 20, 2015 | 05:52 AM
And idk how to check Ecu. (I honestly don't even know where it is located)
Old Mar 20, 2015 | 10:12 AM
widewhite's Avatar
ecu will be on passenger side under dash, pull carpet back and look for a label on ecu tell us what the code is
Old Mar 20, 2015 | 06:32 PM
Te Ecu had this written on it:
37820-p2p-a92
6E 1214-242803
Old Mar 21, 2015 | 04:49 AM
Technical Hero
Does the check engine light work?
Old Mar 21, 2015 | 05:40 AM
It lights up when the key is at accessory then goes away when I start the car. But I hadn't had the car long enough to know if when needed the check engine light comes on.
Old Mar 22, 2015 | 06:56 AM
SpeedRacerEX-R's Avatar
Another thing to look at; coolant temp. Vtec won't crack if the coolant temp is low, yo...
Old Mar 22, 2015 | 12:13 PM
The coolant temp stays right around 1/3 of the way up all the time (after it warms up) never had any high or low spikes
Old Mar 26, 2015 | 10:26 AM
Lol sorry I ment oil temp. How do I check coolent temp?
Old Mar 27, 2015 | 05:57 AM
That's with your engine temp gauge.
Old Mar 27, 2015 | 06:58 AM
Oh I thought that was engine oil temp. Yeah the gauge in the cluster stays right around 1/3 of the way up. Never spikes and warms up relatively fast
Old Mar 27, 2015 | 07:11 AM
I replaced the valve cover gasket yesterday and did an oil change and was looking at the head when the valve cover was off. And noticed it had ex stamped on the camshaft older thingy piece. Does that mean I have the vtec head? But I also noticed and Im not 100% positive but it looked to me like the intake cam didn't have the vtec lobe in between the intake and exhaust lobes. The two cams looked different but I was very confused. (Don't know what I'm supposed to be looking for)
Old Mar 29, 2015 | 07:41 AM
Can you post some pictures?
Old Mar 29, 2015 | 01:12 PM
Sure what would you like pics of. You tell me what you need pics of to help in figuring this out and I'll take them.
Old Mar 30, 2015 | 06:49 AM
The valve cover, dizzy side. I just want to confirm if it has the vtec solenoid.
Old Mar 30, 2015 | 06:53 AM
What is the dizzy?
Do you want cover on or off
Old Mar 31, 2015 | 06:23 AM
I just want to see if has the solenoid by the valve cover. Disregard the two on the tranny, this is the best pic I could find.
Also, dizzy is short for distributor.
Old Mar 31, 2015 | 06:27 AM
It does have both. Top and tranny one
Old Apr 1, 2015 | 05:55 AM
Then you have an auto w/ vtec.
Old Apr 2, 2015 | 06:48 AM
Yes I have an auto but vtec doesn't engage
Old Apr 3, 2015 | 05:55 AM
It probably is. You just can't really tell on a single cam.
Old Apr 3, 2015 | 06:26 AM
antrmo's Avatar
True I was pretty disappointed when i put a y8 head on my y7,,, hardly felt the "crack",lol.
if you have a friend with a scanner ,you could check to see if it is turning on that way I believe.or if it being told to anyway.
