VTEC not kicking in...
Old Jan 23, 2002 | 02:12 AM
prjctCIVIC's Avatar
Default VTEC not kicking in...
i have a h22 civic and everything seems to be fine just when it take it to vtec it doesnt really feel like it kicking in...it just made a loud *** noise but do seem like the power is there....use to get a code 22 but then i'll clear it and it'll go away for awhile and pop back up randomly...any suggestions??? thanks
Old Jan 23, 2002 | 03:52 AM
VR6T's Avatar
Default Re: VTEC not kicking in... (prjctCIVIC)
Obviously you need to find out what the 22 code is first... You can go to nearly automotive store and pick up a repair manual and see what it is. Any brand should have it from Haynes, Chilton or whatever.....
When you reset the computer, naturally the code will go away, but it's still picking up variables (or lack of variables) from around your motor. It's doesn't want to cross over to VTEC if it doesn't know which fuel/air ratio give you without running rich as hell or make you detonate.... In my experience, Check Engine lights will usually come back on after you've restarted your car after driving with a bad sensor. However, it's possible that it would just come on while you're driving... If not, It doesn't mean it's not in a safe mode already.
Hope this helps... Please keep us updated...
[Modified by VR6T, 12:53 PM 1/23/2002]
[Modified by VR6T, 1:24 PM 1/23/2002]
Old Jan 23, 2002 | 06:34 AM
WICKED2's Avatar
New User
i have the same problem
h22 on eg vtec notking in but no engine lite....in u'r case its u'r vtec solenoid
so fix dat go get a vtec solenoid at da dealer and its not dat expensive only $130+.
o yeah what injector r u using.
Old Jan 23, 2002 | 07:28 AM
John's Avatar
New User
Default Re: VTEC not kicking in... (WICKEDII)
code 22: VTEC pressure switch
so it's likely the pressure switch, a bad wire connection, or the VTEC solenoid valve
Old Jan 23, 2002 | 10:17 PM
prjctCIVIC's Avatar
can it be a bad sensor and not even have the check engine light go on???
WICKEDII-i'm using the stock injectors of the prelude motor and using the injector resistor box, so when you changed the vtec solenoid, did you feel a big difference??? thanks
Old Jan 24, 2002 | 06:00 AM
Wicked_R's Avatar
New User
More than likely it is your VTEC solenoid
Old Jan 24, 2002 | 06:10 AM
John's Avatar
New User
Default Re: VTEC not kicking in... (Wicked_R)
if i were you, i'd start with the most simple thing... check your oil... if your oil level is short on even a half quart, there won't be enough oil pressure to activate VTEC... check there first, and then work from there...
if it's the case that your oil level is fine, i can outline for you in detail the steps you would need to take to locate the problem... but i don't have the time this morning...
Old Jan 24, 2002 | 07:14 AM
WICKED2's Avatar
New User
do dis check u'r oil pressure first before buying and sensor or switch
u'r pressure should be at idle 8-10psi and 3000rpm 50psi if u'r pressure is ok
then take out u'r plastic card and call up u'r dealership. then plug that sensor and switch and install a secondary oil line.....its like doing a lsvtec ......u'r not going to lose any oil pressure in this kind of setup. i did this on my h22 and i love it and in top of that i'm using a gsr ecu and u know that if u'r using gsr ecu on h22 u'll get a vteclsg on h22, but if u plug in a secondary oil line u can barely fill it.
hope dis helps
Old Jan 24, 2002 | 08:13 AM
rainforest's Avatar
i know this question is beat but you need 55 p.s.i oil pressure to produce the wonder of vtec so if you have low oil pressure like from not having a oil change in a while or low oil it would prolly throe the code as oil pressure swich.
Old Jan 24, 2002 | 06:26 PM
nickgomez's Avatar
What is this VTEC thing? I just bought a B16 powered SiR and the engine seems to have uniform torque throughout, from idle to 6 or 7 thousand rpm. How do I tell if the VTEC is working or not?
Thanks
Old Jan 24, 2002 | 07:02 PM
Kamin's Avatar
Default Re: VTEC not kicking in... (redteggy)
how about this
before you go spending 150$ on a new solenoid
pull off the filter between the solenoid and the head. clean it, dry it and try again.
thats what happened to me. vtec screams like a **** now.
Old Jan 24, 2002 | 10:11 PM
prjctCIVIC's Avatar
Default Re: VTEC not kicking in... (KAMiN)
damn i hope its just the oil...i will start with checking the oil and from there try the other advice that you guys have mentioned, thanks for all the replys
Old Jan 25, 2002 | 09:49 PM
FitCRX's Avatar
just a quick question...where is the solenoid???B16?
FASTESTCB7inQNZ
Nov 18, 2009 06:41 AM
ganjasnack
Jun 11, 2007 02:38 PM
rugbyplaya85
Nov 18, 2005 10:29 AM
Hondasaurs
Apr 25, 2003 07:30 PM
