Vtec killer cams
Old May 19, 2003 | 07:28 PM
  #26
MikeSarr_GSR's Avatar
Default Re: (drumking15)
even if you do run some upgrades into your B18C/B16 anbd rev it to the sky, do so with caution!
Old May 19, 2003 | 07:59 PM
  #27
bhive9024's Avatar
Default Re: (MikeSarr_GSR)
I think this thread should have been left at how they work, which was the question mind you, and not debate the worthiness of them
IMO the cost of the setup will scare off more people than the lack of understanding anyway
Old May 20, 2003 | 06:52 AM
  #28
blacksheep's Avatar
Default Re: (GSRslowandswap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRslowandswap &raquo;</TD></TR><TR><TD CLASS="quote">if you dont know what they are then you dont need em...... </TD></TR></TABLE>
i agree
Old May 20, 2003 | 08:25 AM
  #29
drumking15's Avatar
if you dont know what they are then you dont need em...... ....
true, but there is always this thing called learnign which most people come to ht for...not just trouble shooting, and in the process they'll learn how vtec cams work also...yes it shouldnt have devidated to any ls/vtec ? but what can you do...all i do is try to help others understand my lgoci behind it all
Old May 23, 2003 | 08:54 PM
  #30
. o 69 o .'s Avatar
it still makes more sense to build up the ls motor then to waste a vtec motor. Its like going down a one way street the wrong way. It does not make sense or cents
Old May 23, 2003 | 08:57 PM
  #31
.RJ's Avatar
.RJ
Default Re: (B16B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B &raquo;</TD></TR><TR><TD CLASS="quote">it still makes more sense to build up the ls motor then to waste a vtec motor. Its like going down a one way street the wrong way. It does not make sense or cents</TD></TR></TABLE>
You can leave a B18C1/C5/B16/etc internally stock and rev pretty high - not true with the LS motor. Balancing and rod bolts will not solve this problem.
Old Jun 3, 2003 | 01:09 PM
  #32
drumking15's Avatar
obviously you've never seen a good ls/vtec setup...not to be a grunt about it but a balanced ls/vtec will rev as high as a b18c no doubt! but imho why would you be revving anywhere's past 9 grand or so, unless you are running the vtec killer cams most powerbands drop off after 9000+
Old Jun 3, 2003 | 01:27 PM
  #33
sivik2nr's Avatar
Default Re: Vtec killer cams (jsxtek)
The evo 8 is using 'them' too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">The Lancer Evolution VIII's camshafts are hollow. The reduction in weight in reciprocating parts like the camshafts is crucial to achieving the free-revving, torque-churning power band. </TD></TR></TABLE>
AhSuM-EK
12
Sep 30, 2011 08:48 PM
projectef
53
Sep 18, 2010 03:53 PM
D17alltheway
Honda Civic (2001 - 2005)
19
Jun 9, 2008 03:05 PM
Brown-tec
Nov 3, 2005 08:41 AM
IN VTEC
Oct 6, 2002 10:03 AM
