Vtec doesnt engage smoothly
Old Feb 10, 2004 | 01:47 PM
WuRKD b16's Avatar
Default Vtec doesnt engage smoothly
i have a b16 running wit a reprogrammed p28 vtec crossover is 5900-6kRPM. I also have a vafc and set vtec at 5k. When it hits vtec at 5k it doesnt feel normal like power is bein held back then around 6k it pulls harder but from 5k to 6k it feels restricted. Like the title says it doesnt engage smoothly. However when i set vtec at 6k it doesnt do this. Anyone know why and if setting it at 5k is actually hurting performance because vtec isnt smooth? Need some help thanks
Old Feb 10, 2004 | 02:44 PM
99spanishGT
Guest
Posts: n/a
Default Re: Vtec doesnt engage smoothly (WuRKD b16)
are you still getting a power jump ,if so u cant be slower, also i think some engines have 2 stage VTEC im a H-guy so i only know 1 stage!
Old Feb 11, 2004 | 03:35 PM
WuRKD b16's Avatar
Default Re: Vtec doesnt engage smoothly (spanishlude)
hmm yea i still get a jump but i was wondering if setting it back to 6k where it engages smoothly, if that would be better then setting it 5k and having it not engage smoothly. Anyone else have info for me
Old Feb 11, 2004 | 05:24 PM
Jimmy's Avatar
Global Moderator
any cel's?
seems normal to me
Old Feb 18, 2004 | 05:58 PM
WuRKD b16's Avatar
Default Re: (USDMDC2)
Nope no cels
Old Feb 18, 2004 | 06:48 PM
TIRENECK's Avatar
Default Re: (WuRKD b16)
what i would do is go buy a new fuel filter, if not recently replace, and injector cleaner.
Old Feb 18, 2004 | 07:45 PM
boostn420's Avatar
Default Re: (TIRENECK)
why would you do that, what could that possibly do.
Leave your vtec a little higher. Opening it too early hurts performance just like a car with a big cam barely idles. The vtec lobes are too much for lower rpm's.
Old Feb 18, 2004 | 08:06 PM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WuRKD b16 &raquo;</TD></TR><TR><TD CLASS="quote">i have a b16 running wit a reprogrammed p28 vtec crossover is 5900-6kRPM. I also have a vafc and set vtec at 5k. When it hits vtec at 5k it doesnt feel normal like power is bein held back then around 6k it pulls harder but from 5k to 6k it feels restricted. Like the title says it doesnt engage smoothly. However when i set vtec at 6k it doesnt do this. Anyone know why and if setting it at 5k is actually hurting performance because vtec isnt smooth? Need some help thanks</TD></TR></TABLE>
if your motor is stock, leave the crossover at the stock 5500rpm crossover. your engine is getting too much cam too soon. honda put it at 5500rpm for a reason.
if you want to experiment (just to feel the difference)...set vtec at 4000, and then at 7000...see which is a bigger difference (HUGE extreme..just for testing)
mike
Old Feb 19, 2004 | 09:55 PM
WuRKD b16's Avatar
Default Re: Vtec doesnt engage smoothly (MikeMAN)
i have crower st 2 cams, full crower valvetrain, 3 angle valve job, slightly ported, milled head, ctr pistons.
Old Feb 19, 2004 | 10:05 PM
MikeMAN's Avatar
mess around with "the tec" see if that helps..
mike
Old Feb 19, 2004 | 11:18 PM
InjectedPerformance's Avatar
We sell parts.
Go to a dyno! To many variables. I bet u dont have chit
Old Feb 19, 2004 | 11:36 PM
Syner-G-Racing LLC's Avatar
Default Re: Vtec doesnt engage smoothly (primo8998)
if you change the solenoids engagment you have to compensate for the extra fuel and air correction needed which you can do with your vafc, with out setting the vafc's maps you want get any more power, basicaly all you did was switch from the primary lobes to the secondary lobes which are v tec your ecu want advance or retard the timing or compensate the fuel.
Old Feb 22, 2004 | 02:04 PM
WuRKD b16's Avatar
Default Re: Vtec doesnt engage smoothly (Syner-G-Racing)
thanks
Old Feb 22, 2004 | 02:09 PM
Kamin's Avatar
you need to go to a dyno
do not **** around with a VAFC's vtec engagment espically if you have no idea what you are doing.
Old Feb 22, 2004 | 02:33 PM
fasterb16hondasi's Avatar
I ran similar set up on my stock bottom end b16 with crower stage 2 cams and i had to run vtec ingagement at 5900 rpm cause anything less it would lose power and anything more it would do the same.
Old Feb 22, 2004 | 03:34 PM
senpai's Avatar
Default Re: (fasterb16hondasi)
Well, with the larger cams you'd probably want/need a higher VTEC activation point
hehu
Dec 1, 2009 08:46 PM
little dx that could
Sep 27, 2007 04:25 AM
nissaninahondaworld
Jan 4, 2006 06:13 PM
pbizzlegsr
Jun 30, 2004 03:14 PM
-iLLuZioN-B18C1
Jun 14, 2003 01:48 PM
