VTEC Controler....
Old Jun 2, 2003 | 12:22 AM
hrc_385's Avatar
Default VTEC Controler....
Hello,
I plan to buy A'PEX V-TEC AFC Digital V-TEC Controller, it's 340$;
http://www.modacar.com/product...AAPE/
Have few question about it;
- are there some bad sides of vtec controler?
- does vtec controler damage engine?
- to install vtec controler, must i have some other modification, or vtec controler can be installed on default engine setup?
- do you recommend vtec controler from some other brand?
I plan to buy DC Sports 4-1 Ceramic Header Systems together with controler, do you have some shop in USA to recommed, with good prices & delivery in 10 days?
Thanks for help....!
Old Jun 2, 2003 | 12:37 AM
IN VTEC's Avatar
Default Re: VTEC Controler.... (hrc_385)
You can only add so much fuel with the AFC before you max out the MAP input voltage.
Use both or either an adj fuel pressure regulator or bigger injectors as needed to primarily increase fuel input and the VAFC to tone it down as necessary.
Of course, you won't know which items you'll need to use until you dyno the car with a wideband to have a look at your AFR's.
I happen to like the Apex'i unit the most. It's got a good interface with big, easy to use buttons and intuitive navigation.
Old Jun 2, 2003 | 03:08 AM
SlapSmak's Avatar
290$ shipped here:
http://www.groupbuycenter.com/buy.aspx?id=10438
the fields controller is also nice, i have had both and field is easier to program. not the kewl vf display though
Old Jun 2, 2003 | 03:24 AM
hrc_385's Avatar
Thnx on answer & help...
I see, D.I.Y. will not be able to install controler
Will find some Honda tuner near me, to install it. So, your suggestion is to put car on dyno before instalation, i hope that tuner now details about it
Sorry for stupid questions, but I'm totaly newbie about controler. If you have some link, or hint for instalation, thnx...
How much power you get on wheels, time on 1/4?
Old Jun 2, 2003 | 04:34 AM
Xsi's Avatar
Xsi
Go withthe Apexi, I have a Field and have had problems with it.
Old Jun 2, 2003 | 05:26 AM
hrc_385's Avatar
Default Re: (Xsi)
Thnx..
Field is US brand, or?
Before installing controler, is best solution to install complete exhaust (headers, pipes...)?
Or, if i install controler, set it up for my car, and then few month after put new exhaust... Do i must again setup controler?
Old Jun 2, 2003 | 06:03 AM
Xsi's Avatar
Xsi
You can install it any time but if your setup changes considerably you will need to go to the dyno again to get it back to optimum settings. So probably best to get some mods first.
I think Field is Japanese
Old Jun 2, 2003 | 06:56 AM
hrc_385's Avatar
Default Re: (Xsi)
Thnx...
I have read Apexi manual for V-AFC... In manual say that you can "adjust engagement point betwen 3000-7000 rpm"...
What i get when adjust engagement on 3k rpm? Can i damage engine?
What is best setup (engagement of vtec), for;
- track
- drag race 1/4
- higway
Sorry if I'm boring, but have a lot question, and cannot find answer on some other place
Old Jun 2, 2003 | 07:26 AM
Xsi's Avatar
Xsi
The only way to find the optimum engagement point is to get a professional to tune it on a dyno, then you'll probably want to leave it there all the time.
You wont notice any gains from having it as low as 3000
ahunt01
May 9, 2003 08:02 AM
el arbi
Mar 14, 2003 04:03 PM
RexB16
May 4, 2002 03:27 AM
CivicEsEye
Jan 5, 2002 02:21 PM
