vtec cam specs...
Old Feb 12, 2003 | 05:20 AM
vdubg60's Avatar
Default vtec cam specs...
does anyone here know the specs of the cam???like duration and all that ..........
[Modified by vdubg60, 9:52 PM 2/12/2003]
Old Feb 12, 2003 | 06:10 AM
TimoneX's Avatar
New User
Default Re: vtec cam specs... (vdubg60)
Uh...any particular cam?
Old Feb 12, 2003 | 06:32 AM
vdubg60's Avatar
Default Re: vtec cam specs... (TimoneX)
THE cam the comes in the engine. i guess if there is more then one v tec came what are the specs?
whenever the v-tec kicks in, what degree is the cam set at??
Old Feb 12, 2003 | 06:38 AM
TimoneX's Avatar
New User
Which engine? There are several different Vtec engines & for the most part they all have different cams in them stock.
Your 2nd question makes no sense whatsoever to me. Perhaps I've just not had enough coffee.
Old Feb 12, 2003 | 12:55 PM
vdubg60's Avatar
ok heres an example....in my g60, i have a 260/268 degree cam. Once i hit 4k rpm, it drops to from 268 to 260(or the other way around)
does anyone have ANY specs on ANY vtec's at all??????????
Old Feb 12, 2003 | 01:02 PM
tinkerbell's Avatar
what the hell are you talking about?!?!
there are too many Honda VTEC cams to list!!!
fool.
which cam do you wnat specs on? at what lift?
t..
Old Feb 12, 2003 | 01:19 PM
vdubg60's Avatar
Default Re: vtec cam specs... (tinkerbell)
im a fool????????? ANY VTEC CAM!!! its not hard
btw, i do not own a Honda. Sorry for coming to your forums for info. gheeash
[Modified by vdubg60, 10:21 PM 2/12/2003]
[Modified by vdubg60, 10:22 PM 2/12/2003]
Old Feb 12, 2003 | 01:29 PM
tinkerbell's Avatar
oh you just want some random info, yeah, OK...
i thought you might actrually NEED the info?!?!
sheesh!
here are the specs for a B16a camshafts (on VTEC lobe)
Duration 265/267, Dur @ .050" 219/214, Gross Lift w/1.55 .412/.379
if you had searched you would also have found this thread listing all the aftermarket cam spects too...
https://honda-tech.com/zerothread?id=230636
t..
Old Feb 12, 2003 | 05:20 PM
vdubg60's Avatar
so in theory...the 260/268 cam is pretty much the same ...or same idea and function, as a vtec..
i was just wondering about that tho...thanks for the info.
i got the same name on the vortex in case you ever need any vw help...
actually if there are any guys in new jersey, or eastern PA. there is a honda/vw g2g organized coming up soon. reply back on this thread if you want some info on that .
later
Old Feb 12, 2003 | 05:24 PM
tinkerbell's Avatar
ahhhhh, i see...
you ARE a troll!
t..
Old Feb 12, 2003 | 07:20 PM
sgT's Avatar
sgT
you sure those #s arent at .040"??
alljapanese cam specs are usually listed at 1mm...
Old Feb 12, 2003 | 07:30 PM
tinkerbell's Avatar
Default Re: vtec cam specs... (sgT)
Stephen, you would have to ask Spade, they are his numbers...
https://honda-tech.com/zerothread?id=230551
t..
Old Feb 12, 2003 | 07:38 PM
tinkerbell's Avatar
ahhh, further searching reveals that these no.s are allegedly at 0mm lift...
see here: http://homepages.paradise.net.nz/asmsbm/camspecs.htm
anyone actually measured the specs them self or waht?
t..
Old Feb 12, 2003 | 08:35 PM
sgT's Avatar
sgT
thefirst numbesr are total duration, the next numbers should be at .040
Old Feb 12, 2003 | 09:06 PM
sgT's Avatar
sgT
http://ghettoracer.com/camtest.html
Old Feb 13, 2003 | 09:55 AM
vdubg60's Avatar
ahhhhh, i see...
you ARE a troll!
t..
i am a troll??? cute...
your calling me a troll, yet your username is tinkerbell
[Modified by vdubg60, 6:55 PM 2/13/2003]
Old Feb 13, 2003 | 10:06 AM
vdubg60's Avatar
what the hell????i try to come to another forum and i get this spit. grow up
Boosted_90Teg
Jun 28, 2013 09:41 PM
tevezjdm3012
Jun 4, 2011 07:29 PM
Johnny_9
May 13, 2006 05:35 PM
christof
Apr 29, 2004 10:20 PM
