vtec cam specs...
Which engine? There are several different Vtec engines & for the most part they all have different cams in them stock.
Your 2nd question makes no sense whatsoever to me. Perhaps I've just not had enough coffee.
ok heres an example....in my g60, i have a 260/268 degree cam. Once i hit 4k rpm, it drops to from 268 to 260(or the other way around)
does anyone have ANY specs on ANY vtec's at all??????????
btw, i do not own a Honda. Sorry for coming to your forums for info. gheeash
[Modified by vdubg60, 10:21 PM 2/12/2003]
[Modified by vdubg60, 10:22 PM 2/12/2003]
oh you just want some random info, yeah, OK...
i thought you might actrually NEED the info?!?!
sheesh!
here are the specs for a B16a camshafts (on VTEC lobe)
Duration 265/267, Dur @ .050" 219/214, Gross Lift w/1.55 .412/.379
if you had searched you would also have found this thread listing all the aftermarket cam spects too...
https://honda-tech.com/zerothread?id=230636
t..
sheesh!
t..
so in theory...the 260/268 cam is pretty much the same ...or same idea and function, as a vtec..
i was just wondering about that tho...thanks for the info.
i got the same name on the vortex in case you ever need any vw help...
actually if there are any guys in new jersey, or eastern PA. there is a honda/vw g2g organized coming up soon. reply back on this thread if you want some info on that .
later
later
Stephen, you would have to ask Spade, they are his numbers...
https://honda-tech.com/zerothread?id=230551
t..
t..
ahhh, further searching reveals that these no.s are allegedly at 0mm lift...
see here: http://homepages.paradise.net.nz/asmsbm/camspecs.htm
anyone actually measured the specs them self or waht?
t..
t..
ahhhhh, i see...
you ARE a troll!
t..
you ARE a troll!
t..
i am a troll??? cute...
your calling me a troll, yet your username is tinkerbell
[Modified by vdubg60, 6:55 PM 2/13/2003]
Johnny_9
May 13, 2006 05:35 PM
