vtec always on
Old Oct 5, 2005 | 06:11 PM
powelljw's Avatar
Default vtec always on help!!!
the vtec is always on according to my data logger ecu control 5
how do i turn it off ? bc it is runnig on the high cam all the time si it won't idle
88 crx si
chiped p28 uberdata
skunk 2 stage 2 cam springs
built 9:1 comprestion
Modified by powelljw at 7:34 PM 10/5/2005
Old Oct 5, 2005 | 06:13 PM
powelljw's Avatar
bump
Old Oct 5, 2005 | 06:32 PM
slomofo's Avatar
GDD Member
Follow your wiring and find out where it's grounded. Are you sure your data logger is accurate?
Old Oct 5, 2005 | 06:40 PM
powelljw's Avatar
Default Re: (slomofo)
yeah it would make sense if it were running on the high cam is will barely idle
how would you say to check the wiring ? just check for the 12volt at the slinoid?
Old Oct 5, 2005 | 07:17 PM
Combustion Contraption's Avatar
Trace the wire back and see if its shorting to ground somewhere.
Old Oct 5, 2005 | 09:41 PM
wetnaps's Avatar
Default Re: vtec always on help!!! (powelljw)
when you do idle what rpm's does it stay at???
Old Oct 6, 2005 | 05:44 AM
powelljw's Avatar
if i unplug the idel air control it will warm up at 1500rpm then drop to lik e150-250rpm
if i plug it in it will surge to 3250rmp to wrm up the drop to 800 and kinda idle fine
Old Oct 6, 2005 | 05:46 AM
powelljw's Avatar
i do'nt want it to surge to 3000 on start up because the is whorable for the engine on start up with no oil in it
also it seems to bog out untill 3500 rpms then it is fine and pulls hard
92lx
Feb 18, 2013 08:18 AM
96CivicBoostCoupe
Jul 22, 2005 12:26 PM
Red_Si
12
Feb 16, 2003 04:17 PM
sporkcrx
Oct 22, 2002 04:13 AM
vti-R
Jun 21, 2002 08:01 PM
