Viscous LSD issues in a high power FF set-up
I have about 270 fwhp and a viscous LSD in my tranny. When I am taking corners at any considerable speed (usually offramps), I get a fairly load sound which I had previously thought might be some suspension components rubbing (sway bar, bad bushings, etc.). However, today when I took an offramp at about 40mph in second gear and the sound is MUCH worse (louder) than it was when I shifted into third at the same time. This made me wonder if it was possible that this could be coming from the LSD. Thoughts?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g_man1968 »</TD></TR><TR><TD CLASS="quote">I have about 270 fwhp and a viscous LSD in my tranny. When I am taking corners at any considerable speed (usually offramps), I get a fairly load sound which I had previously thought might be some suspension components rubbing (sway bar, bad bushings, etc.). However, today when I took an offramp at about 40mph in second gear and the sound is MUCH worse (louder) than it was when I shifted into third at the same time. This made me wonder if it was possible that this could be coming from the LSD. Thoughts? </TD></TR></TABLE>
You may need a flame suit for the bolded statement.
The differential speed is independent of the current gear selection. Were you accelerating?
No, not accellerating. As for the bolded statement, I am not sure why it is flame worthy. Thats really the only time that I am turning at speeds over 30mph. Good point about the differential speed being independent of gear. I wonder if it could be a tranny issue? The experience surely makes it sound like it is not merely suspension components...
Perhaps you have a bad mount on the engine or transmission. Shifting to a lower gear would have increased the forces on those mounts. It's just a thought.
vtisturbo
Transmission & Drivetrain
22
Apr 24, 2019 05:14 PM
