Video: ABS codes, and how to read them Help.
Old May 27, 2012 | 11:48 PM
t0eKnEe's Avatar
Icon2 Video: ABS codes, and how to read them Help.
My 97 Accord has an ABS light that comes on. I first noticed the front left wheel sensor was not in. Cleaned it and put it on. Now when I first turn the car on, the abs motor does a loud wine 3 or 4 times before it stops and the abs light stays on. Brakes are also very bad.
I had to stop earlier this week and when I hit the brake, my car swirved very bad to the right losing control of my car but luckily gaining control not hurting anybody or even killing myself.
These are the codes I got from jumpering the 2 wires on the connector under the glove box.
Any inputs?
http://youtu.be/QbcZ2hQfqq0
Old May 28, 2012 | 10:32 PM
t0eKnEe's Avatar
Default Re: Video: ABS codes, and how to read them Help.
anybody?
Old Jul 22, 2012 | 06:46 PM
Onefreak's Avatar
always best to buy a manual it will tell you the codes and explains how to change the brakes ...abs light coming on usually means either a wheel speed sensor is not picking up a signal from the exciter ring (bad or dirty exciter ring or wheel speed sensor) might wanna check the sensor 1st since it was not in ....then check the fluid and change the brakes if they are bad.. good luck hope it helps.
vxnine
Sep 12, 2016 05:18 PM
manuelesr
Apr 13, 2008 01:08 PM
spooncivic1
Jan 11, 2006 08:09 PM
Rob!
Jan 12, 2005 05:53 PM
TerribleOne
Mar 19, 2003 10:59 AM
