very strange problem (ecu wiring)
Old Apr 26, 2007 | 07:44 AM
dazcivic's Avatar
Default very strange problem (ecu wiring)
1stly i did have an emanage and an apexi vafc fitted to my car and the wiring was a proper mess (i didnt do it) and i found a diagram that shows where all the wires for the ecu plugs should be and sorted it out
the problem being that the diagram wasnt exactly the same as mine so i had to work some of it out for my self and some of the wires that were shown in the diagram werent even on the ecu loom but i thought id sorted all the changes that were made when above parts were fitted
my problem now is ive just plugged in my p28 with crome and im getting 2 error codes 22 = vtec pressure switch
36 = jdm only traction control (my car aint jdm and i dont think the p28 is off a jdm car)
the code 22 is the main problem ive gone back to check the wiring and on block C number 10 there should be a blue and black wire that is the vtec pressure switch but not only is there no wire connected to number 10 but there is no blue and black wire on the ecu loom
please help
the car is a 99 em1 uk spec (sure its same as us spec)
and this is the diagram i followed
http://technet.ff-squad.com/wiring.obd2b.htm
NaturalLS-V
Mar 28, 2012 11:18 PM
Stadler
Jan 14, 2010 06:32 PM
blackEGFTW!
Sep 4, 2009 04:25 AM
boosted98acura
Jan 27, 2008 02:56 PM
triceeetrev
Sep 10, 2003 01:13 PM
