very strange highway speed B16 performance
WHen the car warms up, i.e. cruising 10 min on the highway, cruising at a constant throttle position at 60MPH, the motor appears to be running out of gas. It seems like the ECU leans it out and I have to touch trottle a little more to get smooth cruising again.
Any ideas?
THis is with B16, PW0 and constant fuel Pressure of 39PSI. Injectors are clean. Plugs and Distributor are fine.
Any ideas?
i think that may be kinda normal..i drive to california and back here to arizona alot and it seems like that happens a little,nothing is perfect(that is untill i went over every aspect of the motor:air/fuel/spark)i would suggest doing a good tune-up..add some extra grounds..check all your electrical connections and use good quality spark plugs like ngk or denso..good luck
at first it made sense that the TPS could be the culprit but I checked it on my scope and output is perfect. Hmmmmm.
when did it start? how long has it bee doing this?
have you triple checked your wiring into your PWO?
have you tried swapping the 1 and 2 o2 swires around on the ecu
mine did this i swapped the o2 pins around at the ecu fixed it
