How do I Retard the Timing on OBD-2 LS
Old Oct 20, 2003 | 08:16 AM
integranator's Avatar
Default How do I Retard the Timing on OBD-2 LS
I've heard you have to jump a cable in the ecu to be able to retard ignition from the distributor, is this true?? How can I pull out some timing on my OBD-2 LS??
Old Oct 20, 2003 | 08:36 AM
Padawan's Avatar
Darth ModerVader
Default Re: How do I Retard the Timing on OBD-2 LS (integranator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integranator &raquo;</TD></TR><TR><TD CLASS="quote">I've heard you have to jump a cable in the ecu to be able to retard ignition from the distributor, is this true?? How can I pull out some timing on my OBD-2 LS??</TD></TR></TABLE>
Yes, use a paper clip or a piece of wire to jump the service connector under the passenger-side dash, then grab your timing light, loosen the distributor bolts, and adjust as desired.
Old Oct 20, 2003 | 09:09 AM
cstay's Avatar
look under the pasingers side dash u will se a green rubber piec in there there are two connectors take the one with 2 wires going into it and jump them. If u want more info and pictures go to http://www.team-integra.net then go to the articles section.
92integraVTECgsr
Apr 14, 2008 06:54 AM
integrx
May 12, 2004 02:48 PM
integranator
Aug 30, 2003 08:23 AM
Zuerst
Jul 29, 2003 04:43 PM
