VERY simple question that i should know but don't
Old Aug 12, 2003 | 06:20 PM
carsaregood's Avatar
Default VERY simple question that i should know but don't
if you spin one wheel one direction, which way is the other supposed to turn? opposite right?
Old Aug 12, 2003 | 07:08 PM
slo2kgsr's Avatar
Default Re: VERY simple question that i should know but don't (carsaregood)
yes if you have the car up in the air withthe motor off and spin one tire in one direction then the other will go oppisite
Old Aug 12, 2003 | 07:13 PM
Default Re: VERY simple question that i should know but don't (tegraLS97)
THANK YOU. ok mine spin the same way.. and my axles do not come out with a crowbar... i think my diff is locked somehow. it kinda happened from out of nowhere, is this a common occurance with d-series cable trannies?? anyone have any idea about what could have happened? thanks again.
Old Aug 13, 2003 | 05:17 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegraLS97 &raquo;</TD></TR><TR><TD CLASS="quote">yes if you have the car up in the air withthe motor off and spin one tire in one direction then the other will go oppisite</TD></TR></TABLE>
That's true if it's in gear (manual) or in park (auto). If it's in neutral, it might go either way or maybe not turn at all. Depends on brake drag & bearing preloads.
If it's in gear (or park) and the differential is seized, it shouldn't be able to turn at all.
Old Aug 13, 2003 | 12:12 PM
Default Re: VERY simple question that i should know but don't (JimBlake)
in gear, the axles do not turn...
how can i get them out so i can pull the tranny?
Old Aug 13, 2003 | 02:08 PM
allwheelerman's Avatar
pry the hell out of them
Old Aug 14, 2003 | 12:37 AM
Default Re: VERY simple question that i should know but don't (allwheelerman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allwheelerman &raquo;</TD></TR><TR><TD CLASS="quote">pry the hell out of them </TD></TR></TABLE>
thank you for your immensely helpful reply
Old Aug 14, 2003 | 03:55 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carsaregood &raquo;</TD></TR><TR><TD CLASS="quote">thank you for your immensely helpful reply</TD></TR></TABLE>Well, maybe he's right. I haven't had to take my axles out yet, but people say you have to pry kinda hard. Make sure the car doesn't fall of the stands...
Old May 18, 2004 | 05:04 PM
just a follow up on a really old thread -
turned out my spider gears were broken, thats why the wheels turned the same way and why the axles were stuck.. not sure if its common to break diffs or not.
Old May 18, 2004 | 05:10 PM
civickiller's Avatar
well usually when soemthing goes in the tranny its the diff
Old May 18, 2004 | 06:10 PM
spaceman's Avatar
Default Re: VERY simple question that i should know but don't (civickiller)
when you fix it dont try to do anymore burnouts bro
Old May 18, 2004 | 10:27 PM
Default Re: VERY simple question that i should know but don't (spaceman)
fear and loathing, nice.
its been fixed, a long time ago, i just did a search on myself and saw that i never concluded this thread, so i thougth i would. i didn't break it doing burnouts.
Felliph3
Feb 23, 2007 04:07 AM
Dealer Leaf
Nov 16, 2006 05:02 PM
J1A1H
17
Jan 11, 2006 05:07 PM
ekim952522000
13
Aug 24, 2005 08:02 PM
00WhiteEKy
Apr 14, 2003 10:19 AM
