vanos and other bmw trickery
Old Jan 10, 2003 | 01:58 PM
e36s52's Avatar
Default vanos and other bmw trickery
VANOS is short for VAriable NOckwellen Steuerung. The original VANOS system varied the valve timing on the intake cam. Unlike VTEC, it does not vary lift. The double-VANOS system found on newer BMW's varies valve timing on both the intake and exhaust cams. These adjustments are infinite within their ranges of operation and help to provide the broad, flat torque curve for which BMW's are known.
Perhaps more interesting is the the latest from BMW: a system called VALVETRONIC. It has been on the European economy Bimmers for a couple years and has now come to America in the new 7-series. It is a throttle-less intake with infinitely variable intake valve timing and lift. So when you step off of the "throttle" pedal, the valves simply don't open as much to keep air out.
Just some basic info about these systems for your reading pleasure...
Old Jan 10, 2003 | 01:59 PM
e36s52's Avatar
Default Re: vanos and other bmw trickery (e36s52)
sorry, i meant for this to be a reply under "Do other cars have VTEC?", but hit the wrong button.
Old Jan 10, 2003 | 03:36 PM
hondaeg5's Avatar
it also has variable intake runners.
homebrew
Aug 23, 2015 11:37 AM
Rocket
281
Mar 6, 2014 02:13 PM
oleshifty
Feb 12, 2012 02:17 PM
apexii
Feb 22, 2002 03:53 AM
Honda_Fanatic
Jun 28, 2001 02:48 PM
