which valve train?
Old Feb 3, 2003 | 11:58 AM
marc.ejay-twenty's Avatar
Default which valve train?
i've searched and read a lot of posts concerning using itr outer and stiffened aftermarket inner valve springs with skunk stage 2's. i was wondering if there's any difference in power using the skunk valve train as opposed to the itr outer + stiffened inner. anyone got any dyno charts or personal experience?
Old Feb 3, 2003 | 02:28 PM
Padawan's Avatar
Darth ModerVader
Default Re: which valve train? (marcdogg816)
Overly stiff springs could potentially reduce power due to the increased force needed to open the valves. You won't see any gain by running one or another unless one set is overly stiff or the other set is not stiff enough.
Old Feb 3, 2003 | 02:55 PM
joe_bocc's Avatar
Default Re: which valve train? (Padawan)
IMO, for valve springs it's best to stick with the same manufactures as the cams your using. If you got the Skunk2 cams, then go with the Skunk2 springs.
Old Feb 3, 2003 | 05:52 PM
Default Re: which valve train? (joe_bocc)
thanks guys...anyone else?
prodragEG
Sep 26, 2007 02:51 PM
aznromeo069
Mar 16, 2007 09:50 PM
PowerHouse
Oct 7, 2004 07:42 PM
vinasity
Jun 21, 2004 04:27 PM
tbud454
May 22, 2004 11:20 AM
