valve timming / camchaft timming
Old Oct 8, 2005 | 11:04 PM
eater_eg6's Avatar
Default valve timing / camchaft timing
i saw some tunner used the dial gauge to check the valve timing... why they do that ??? how about just adjust the timing by the adj cam gear without checking the timing with the dial gauge ? thanx
Old Oct 9, 2005 | 06:57 AM
drdisco69's Avatar
Default Re: valve timing / camchaft timing (eater_eg6)
It's called degreeing the cams, and it is done to make sure that they are set so that the valves open and close according to the manufacturers specs. That way you know where you are as far as timing goes, and can adjust from there.
Old Oct 9, 2005 | 10:40 PM
eater_eg6's Avatar
Default Re: valve timing / camchaft timing (drdisco69)
thanx..
accordforme
Oct 8, 2010 08:03 PM
stagen
Dec 21, 2008 07:31 AM
euG3dc2r
Feb 23, 2005 03:45 AM
555R
Jan 11, 2005 05:46 PM
SH LUDE
Oct 28, 2002 08:22 PM
