Valve to Piston clearance
Hi!
I'm building currently a B18C5 engine with 11.5:1 Pistons and Skunk2 Stg 2 Cams.
The head is slightly modified.
How much clearance should be between the Pistons and the Valves to run the engine save?
TIA
Doc
TIA
Doc
I had these cams and because I did not clay the block I ended up with 7 bent valves and 1 broke one that went thru the piston and smashed the combustion chamber of my beautiful ported head. Better safe than sorry
Thank you for your help!
I've clayed out with vtec locked and camgears set to +4,-4.
The result are: in 0.094", ex 0.063"
@B16aEK: sorry to hear that!
Doc
[Modified by doc, 2:33 AM 6/24/2002]
Doc
Spawne32
Dec 21, 2010 08:47 PM
ohsnapzafingcu
May 31, 2007 06:58 PM
lyckaon
Nov 20, 2005 11:05 PM
