Angle of valves in a B head?
Attempting to use B pistons in a 12 valve block. The 12 valve has a different angle and the reliefs will have to be adjusted and I'm trying to judge how much before I buy.
either way, you're better off just claying it. a comment from (even a well-intending and very knowledgeable) stranger on the internet is no substitute for good engine building practice.
whenever you're fitting non-standard pistons (anything other than the original part number) into an engine, you clay them to check the piston to valve clearance. don't short cut it.
Spawne32
Dec 21, 2010 08:47 PM
