valve guides question
Old Aug 18, 2004 | 06:08 AM
Special B's Avatar
Default valve guides question
hi everybody,
I have a B16A2 cylinder head port and polish and more... the valves guides there shorten to allow more flow, u think i risk to have problems to come? or i risk anything?
thx all
Old Aug 18, 2004 | 07:52 AM
Special B's Avatar
Default Re: valve guides question (Fabulous Vtec)
anybody ??!!
Old Aug 18, 2004 | 09:57 AM
Special B's Avatar
hey guys where are u...?!
Old Aug 18, 2004 | 10:16 AM
MightyMouseTech's Avatar
The guides will wear out faster than if they were untouched.
Old Aug 18, 2004 | 10:21 AM
Special B's Avatar
Default Re: valve guides question (MightyMouseTech)
you can explain more precisely please ?
Old Aug 18, 2004 | 10:24 AM
spaceman's Avatar
i read somewhere that doing that will increase flow but wont be as reliable in the long run...good luck
Old Aug 18, 2004 | 10:31 AM
Special B's Avatar
Default Re: valve guides question (spaceman)
the joint of valves will be changed more quickly than envisaged, but I want to know if the valves can become unstable because of the guides shortened or that has exchange nothing...?
Old Aug 19, 2004 | 04:04 AM
Special B's Avatar
up !
Old Aug 19, 2004 | 07:49 PM
flow-zilla's Avatar
i port heads and i also cut guides and i can say that you will be ok the only way you are gonna have any problems at all is if the guides where worn to begin with ... but for the most part you are ok .. just dont over rev or miss shift or any thing like that and you will be ok.. and if you do feel wierd about it than contact you porter and have him replace guides.. but you will have to redo your valve job again
Vtec04
Engine Machining & Assembly
Nov 10, 2017 02:23 PM
bluedlude
20
Mar 20, 2007 06:08 PM
adam94lude
Oct 16, 2005 03:26 PM
CHAHONDA
May 20, 2004 11:48 AM
Adampops
Feb 17, 2003 09:06 AM
