valve cover question/tech question
Old Dec 14, 2008 | 10:39 AM
slow-ef's Avatar
Default valve cover question/tech question
whats the name of this piece and can it be replaced?
and another question is that my car sometimes runs ruff it has no power until it warms up.
and sometimes i can rev the car up and it will start to run right it sounds like a subaru with no power i think its time for a new exhaust if any one could help me out with this thanks
Old Dec 14, 2008 | 10:46 AM
WeirdBeard's Avatar
Default egr
exhaust gas return bung, yes.
Old Dec 14, 2008 | 10:48 AM
slow-ef's Avatar
ok thanks
Old Dec 14, 2008 | 12:28 PM
GhostAccord's Avatar
I'm pretty sure that is the fresh air intake port for the PCV system. It is connects to the air intake tube before the throttle body.
Old Dec 14, 2008 | 03:57 PM
D-Clem's Avatar
everytime ive had a car run like that and sound like a suby its been a chipped valve due to nitrous, but most likely the reason it sounds like that is a misfire, that could be any number of things that would cause that, now its up to you to determine why.
Old Dec 14, 2008 | 05:25 PM
slow-ef's Avatar
yeah i was thinking it was a misfire so i changed the plugs, wires, distributor cap, and rotor and its still doing it could the distributor be going bad or something
Old Dec 15, 2008 | 05:27 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
That port on the valve cover has nothing to do with the EGR system. GhostAccord's post was correct.
As for running rough when first starting, is your FITV working properly? This is the fast idle thermo-valve on the bottom of the throttle body, with coolant lines running to it. It's supposed to make your car idle faster, up around 1500-1800 rpm when it's cold, until it gets up to normal operating temperature.
ludekid4323
Feb 19, 2007 01:59 PM
TranspeedMotorsports
Nov 6, 2006 03:17 AM
hovic
Jun 6, 2006 02:58 PM
