valve clearance w/ ctr pistons in a gsr?
Old Aug 17, 2002 | 09:36 AM
knighteg's Avatar
Default valve clearance w/ ctr pistons in a gsr?
hey guys i am wondering if i put .25mm o.s. ctr pistons in my gsr will there be enough valve clearance? my head is slightly milled due to when i had a blown head gasket they machine shop told me they had to mill the head a little bit because it was slightly warped...this was almost over a year ago. also would i have to update my valvetrain just for the pistons? would i be able to use 91 octane? i have used the searc function and cant get a straight answer for these.
any help would be appreciated ,
thx
Old Aug 17, 2002 | 10:15 AM
lazy bum shaughn's Avatar
Default Re: valve clearance w/ ctr pistons in a gsr? (knighteg)
You wont need to get a stronger valvetrain unless you get juicier cams.
Old Aug 17, 2002 | 10:50 AM
ViZ's Avatar
ViZ
i doubt you should have problems but if you ad cams you should clay the motor for valve clearence
Old Aug 17, 2002 | 10:52 AM
ViZ's Avatar
ViZ
Default Re: valve clearance w/ ctr pistons in a gsr? (ViZ)
http://www.c-speedracing.com/howto/claymotor/clay.html
Old Aug 17, 2002 | 11:06 AM
knighteg's Avatar
the guy i am buying my ctr pistons from says i will have 12.3:1 c/r in my gsr?
and says i can run on pumped 91 oct gas? is this possible?
Old Aug 17, 2002 | 01:37 PM
martini's Avatar
I would think around 12.1:1 would be more accurate. But that depends on a few other things.
Is 91 the highest octane you have in your area?
Old Aug 17, 2002 | 05:09 PM
knighteg's Avatar
Default Re: valve clearance w/ ctr pistons in a gsr? (martini)
well actually there is 100 octane gas too at certain gas stations around my city, but its not to bad only like 3 bux a gallon for 100 oct! do you think i could mix the 100 oct say 3 gallons of that plus mix another 6 gallons of 91 oct to create a full tank for my gsr? are u asking this because of detonation possibilities?
Old Aug 17, 2002 | 08:37 PM
martini's Avatar
No, I was just wondering if you have 92 or 93 and just wanted to go cheap and get the 91 or something like that..
You can run the 91 octane if you are tuned well enough. Do you have any plans for a fuel controller, or programable ecu, like Hondata?
Old Aug 17, 2002 | 10:37 PM
knighteg's Avatar
no i was not aware that i would need a hondata just for pistons? would a vafc work? i might get one of those, or would hondata be alot better?
Old Aug 18, 2002 | 03:03 PM
martini's Avatar
well you don't NEED it.. but you can avoid detonation with good tuning.
a vafc would work.. but yes, hondata would be much better.
Old Aug 20, 2002 | 07:08 PM
MisterB's Avatar
would i be ok running ctr os pistons in a b16 with vafc and the highest octane i can get in my area is 91
Old Aug 21, 2002 | 08:46 PM
MisterB's Avatar
if your worried about clearence and detonation you can go with some itr pistons i know the compression will be lower than ctr in a gsr
Old Aug 27, 2002 | 02:15 PM
HondaGSR's Avatar
--how much of a gain will i see if i put ITR cam's in my GSR??
Chance EG
Apr 6, 2020 11:27 AM
Rheg6
16
Feb 16, 2009 07:17 PM
eg6REDmilano20
22
Jan 22, 2009 12:29 PM
itr1244
Jun 7, 2006 10:55 AM
knighteg
Aug 18, 2002 05:01 PM
