valve clearance specs for jun 3 cams??
Old Jan 8, 2002 | 11:47 PM
infinkc's Avatar
Default valve clearance specs for jun 3 cams??
im installing my cams later this week after my head gets back from the machine shop. Just wondering if i just use stock valve clearance for these? and if so what is it? also need the torque specs for the headbolts thanks!
Old Jan 9, 2002 | 01:42 PM
Padawan's Avatar
Darth ModerVader
Default Re: valve clearance specs for jun 3 cams?? (infinkc)
I believe JUN recommends the factory valve lash specs. for their cams. As for the headbolts, the manual I have says to initially tighten all of them in sequence to 22 ft. lbs, then tighten in sequence again to 63 ft. lbs.
Old Jan 9, 2002 | 09:37 PM
infinkc's Avatar
Default thanks n/m
thanks n/m
Old Jan 10, 2002 | 01:31 PM
John's Avatar
New User
Default Re: thanks n/m (infinkc)
don't most aftermarket cams recommend factory valve clearances?
Old Jan 28, 2002 | 06:04 AM
azn98R's Avatar
Default Re: thanks n/m (DunReit)
I am about to install my JUN3's and I also have spoon 1ply head gasket... is that recommended, I mean would there be enough valve clearance?
Old Feb 9, 2002 | 05:27 AM
Liquidx02's Avatar
Default Re: thanks n/m (azn98R)
clay the motor
HYPROPULSION_R
Aug 5, 2007 07:52 PM
ispkarl
Oct 22, 2003 02:44 PM
genetsang
Aug 12, 2003 12:34 PM
infinkc
Jan 9, 2002 05:07 AM
Toda Party
Jan 8, 2002 11:25 PM
