Valve clearance setting tools? where from
just wanted to know where can i get the tools required to set valve clearances on my car such as the angled feeler gauge. I live in the U.K so id prefer if u could give me a reliabe website or something.
Can valve clearances be set without a Angled feeler gauge
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Sport »</TD></TR><TR><TD CLASS="quote">I set it all the time without angled feeler gauges. any feeler gauges will do. just make sure you have the correct specs for the motor.</TD></TR></TABLE>
If you need a valve tappet wrench, search on Amazon.com.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f1 vtec »</TD></TR><TR><TD CLASS="quote">ok so a valve tappett wrench will do the job of a feeler gauge? ive never set valve clearances before but its worth a try</TD></TR></TABLE>
No. On VTEC heads (if that is what you have), it is difficult to adjust the set screw and lock the jam nut. The valve tappet tool eases that issue. You still need the feeler gauges.
Amazon has both for cheap. Here is the link for the jam nut tool..
http://www.amazon.com/exec/obi...07846
Recently i did a valve adjustment on my b16 for the first time. At sears I bought a set of angled feeler gages and a cheap 10mm box wrench for $10.
Modified the wrench and adjusted the valves. I used this link to get the job done.
http://www.c-speedracing.com/h...t.php
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">Amazon has both for cheap. Here is the link for the jam nut tool..
http://www.amazon.com/exec/obi...07846</TD></TR></TABLE>
Perfect! My local Canadian Tire (like autozone but generally better) carries this brand. It's all cheap stuff but for something like this it doesn't matter. It'll get used maybe 10 times a year if I do it for a few friends so there's no chance in hell I'll buy crap-on for 3 times the price.
Not to threadjack, but can anyone recommend some good feeler guages? Plastic or metal? Are the expensive ones any better than cheap ones?
spidermancivic
Dec 2, 2005 11:21 PM
