Valve clearance D16z6
Old Mar 5, 2004 | 05:12 PM
DelSolSi93's Avatar
Default Valve clearance D16z6
Im going to be checking/adjusting the valve clearances on my Z6 soon and I found these specs:
Valve Clearance
Stock D16A6,D16Z6 and D16Y8 Cams
Intake.....007-.009" (.17-.22mm)
Exhaust...009-.011" (.22-.27mm)
Now those are ranges, is it better to set the clearances on the high end of those numbers, low end of those numbers, somewhere inbetween? Any advice on which, and why would be great, thanks!
Old Mar 5, 2004 | 05:51 PM
InjectedPerformance's Avatar
We sell parts.
Default Re: Valve clearance D16z6 (DelSolSi93)
I would go low, less lift
Old Mar 5, 2004 | 06:01 PM
Chiovnidca's Avatar
I usually adjust them to the tight side of spec just so I don't have to do it again as soon.
Old Mar 5, 2004 | 06:42 PM
We sell parts.
Default Re: Valve clearance D16z6 (Chiovnidca)
Make sure you adjust them at 100F or kinda hot to the touch. Make them tight. The tighter the lash the better. If it is to tight you will not make any compression in that particular cylinder. You will notice a bit of peace of quiet and maybe feel the HP gain.
Old Mar 5, 2004 | 06:53 PM
Chiovnidca's Avatar
Default Re: Valve clearance D16z6 (primo8998)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primo8998 &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you adjust them at 100F or kinda hot to the touch. </TD></TR></TABLE>
Do you mean 100 degrees or less, like Honda recomends?
Old Mar 5, 2004 | 07:34 PM
We sell parts.
Well heat expands cold contracts. So if you can get the medium you are better off. The spec valve lash is for the regular mechanic.
lsegcoupe
Dec 21, 2006 02:05 AM
pumpkyn
10
Jun 23, 2006 10:37 PM
moesrex
May 23, 2006 08:55 AM
JBOCRXsiR
Sep 6, 2004 10:25 AM
