Valve Adjustment tips
Old Aug 11, 2003 | 02:38 PM
Beave0101's Avatar
Default Valve Adjustment tips
I finally decided to make my life easier and I purchased the Snap on tool, and I already have the feeler gauges.
My problem is on crank setting. TDC I can get because the pulley lines up with the timing belt cover.
But my cams are adjusted 2degrees intake and 2degrees exhaust. Will this effect anything?
And also, I can't be 100% exact as I rotate the crank, because the gears are off, will anything be off if I do? thanks.
Old Aug 11, 2003 | 03:38 PM
allwheelerman's Avatar
Default Re: Valve Adjustment tips (Beave0101)
it should be very close, but to get it perfect i would set the gears to zero. Piece of mind really.
Old Aug 11, 2003 | 08:03 PM
MaxSterling's Avatar
Default Re: Valve Adjustment tips (allwheelerman)
+/- 2 degrees is withn stock allowances
Old Aug 11, 2003 | 09:47 PM
Kataku2K3's Avatar
Default Re: Valve Adjustment tips (RoyFokker)
I really wouldn't worry about it, unless you have some wild cams as long as you are not loading the rocker with lift then you'll be fine... As alwheelerman said, if you're really worried go back to 0,0 for the time being... Latez
Old Aug 12, 2003 | 10:48 AM
Beave0101's Avatar
Default Re: Valve Adjustment tips (Kataku2K3)
alright, just to be on the safe side I'll probably just go back to (0,0) they're stage II cams, and after my last valve adjustment everything still seemed off
Old Aug 12, 2003 | 11:47 AM
mike1114's Avatar
I have crower stage one cams in my B18C, I set my cams back to 0,0 to adjust.
speedy8281
Engine Management and Tuning
Oct 5, 2010 10:29 PM
revhardallday
Nov 26, 2008 03:08 PM
mr_magoo
Aug 23, 2008 12:41 AM
super77
Sep 5, 2004 02:19 PM
miahmouse
Apr 14, 2004 11:09 AM
