Valve Adjustment tips
I finally decided to make my life easier and I purchased the Snap on tool, and I already have the feeler gauges.
My problem is on crank setting. TDC I can get because the pulley lines up with the timing belt cover.
But my cams are adjusted 2degrees intake and 2degrees exhaust. Will this effect anything?
And also, I can't be 100% exact as I rotate the crank, because the gears are off, will anything be off if I do? thanks.
I really wouldn't worry about it, unless you have some wild cams as long as you are not loading the rocker with lift then you'll be fine... As alwheelerman said, if you're really worried go back to 0,0 for the time being... Latez
alright, just to be on the safe side I'll probably just go back to (0,0) they're stage II cams, and after my last valve adjustment everything still seemed off
revhardallday
Nov 26, 2008 03:08 PM
mr_magoo
Aug 23, 2008 12:41 AM
