Valve Adjustment Help!
Old Jul 1, 2005 | 10:29 PM
HatchSpeeD's Avatar
Default Valve Adjustment Help!
Ok, so today I decided to replace the 3 valve cover studs/caps I snapped off and while I had the valve cover off I noticed something disturbing. 10 of the 16 Valve adjustment nuts are like hand loose. It sounded like I needed a valve adjustment but DAMN. I'm scared to drive my car now. So I picked up some feeler gauges and basically looked around for a shop manual but every place was sold out. I still don't have a helms and want to make sure i'm doing this right.
On a LS, where do put the feeler gauge between? Is it between the top retainer and the valve adjustment screw? Or is it somewhere between the cam lobe and something else? Also, which feeler gauges should I use or whatever. I read somewhere for an LS the intake should between 0.003"-0.005" and exhaust 0.006"-0.008". I'm going to try and do this in the morning.
Old Jul 2, 2005 | 07:21 AM
HatchSpeeD's Avatar
Bump for some help
Old Jul 2, 2005 | 08:59 AM
IN VTEC's Avatar
Default Re: (HatchSpeeD)
Feeler gauge goes in between the cam base circle and the rocker arm.
Those specs are accurate. Use them.
Old Jul 5, 2005 | 06:44 AM
lokigti's Avatar
Default Re: (IN VTEC)
Actually the feeler guage goes between the tip of the rocker where it touches the top of the valves.
Old Jul 5, 2005 | 12:29 PM
JimBlake's Avatar
Default Re: Valve Adjustment Help! (HatchSpeeD)
At least the ones I've seen, it's like this...
For their DOHC engines, Honda lists the valve clearances between the camshaft & rocker, like IN VTEC says.
For SOHC engines, Honda lists them at the valve stem like lokigti says.
Old Jul 5, 2005 | 01:29 PM
IN VTEC's Avatar
Default Re: Valve Adjustment Help! (JimBlake)
Right on Jim.
gsr96cx
Aug 30, 2008 01:24 PM
4DRmafia
16
Aug 22, 2004 07:51 PM
b18prl
Mar 26, 2003 11:21 AM
fe519
Mar 22, 2003 08:53 AM
LshatchTurbo
Aug 12, 2002 03:28 PM
