Quick questionn about unpluging the vafc
Old Apr 30, 2002 | 09:45 PM
IgniteTeg's Avatar
Default Quick questionn about unpluging the vafc
Will the ecu still function normal back to stock if I unplug the connectors from the vafc??? So that it won't get its vtec signal from the vafc and fuel/timing curves. Because I think that if I unplug the vafc then the ecu won't function no more because it gets its signal from the vafc??? What do you guyz think. Thanks for all help.
Old May 1, 2002 | 03:13 AM
aklucsarits's Avatar
New User
Default Re: Quick questionn about unpluging the vafc (IgniteTeg)
If you have the VAFC wired to the engine harness and then you unplug the V-AFC unit, the car will no longer run at all.
If you want to be able to unplug the V-AFC, you need something like the Field Harness or Kenji's V-AFC harness. See the link in my signature for a pic of the Field Harness.
Andrew
R0Y
Nov 28, 2002 11:18 AM
IgniteTeg
May 1, 2002 03:57 AM
IgniteTeg
Apr 30, 2002 09:19 PM
