Vafc Problem
Old Oct 8, 2002 | 12:34 PM
MisterMino's Avatar
New User
Default Vafc Problem
I installed my Vafc, and after a few hours of driving, the Check engine light comes on. The Throttle sensor then stops working, and the Vtec Intake cam stops engaging. But if i reset the ECU (take the negative terminal off the battery) everything works fine again, but then the next day it does the same thing...any suggestions? btw my wiring i used a wiring harness, and soddered everything on, so i don't think the wiring is a problem...maybe i'm messing up on the initial settings or something, any thoughts are welcome.
Old Oct 9, 2002 | 07:02 AM
leptolude's Avatar
Default Re: Vafc Problem (MisterMino)
get the codes from the CEL, not sure what car your in, but theres a way to get the code on the obd11 prelude without going to a garage. do a search for "shorting ecu code CEL" or somthing. sounds like a wiring problem though, sorry to say. good thing you got the harness (easier to work with, can always go back).
GL and no durring install this time
if your in a H22'er i can help with settings
[Modified by leptolude, 4:03 PM 10/9/2002]
Old Oct 9, 2002 | 08:58 AM
MisterMino's Avatar
New User
Default Re: Vafc Problem (leptolude)
i just took it all out, put it back in.....and now it seems to work like a charm....still clueless as to what was goin on....lol, oh wellz.....well i'm just a GS-R, i have some of my settings fine, i took some of the H22A settings i found, and adjusted them to fit my car, btw what's your settings? thanks
[Modified by MisterMino, 6:01 PM 10/9/2002]
bad-monkey
Dec 3, 2004 06:07 PM
TurboBumblBee
Nov 8, 2003 10:44 AM
TurboBumblBee
Nov 15, 2002 11:08 AM
TurboBumblBee
Nov 14, 2002 01:09 PM
AfEn808
Jan 27, 2002 03:01 AM
