VAFC? Motor wont run right
Old Nov 2, 2004 | 12:09 PM
Brett_Hicks's Avatar
Default VAFC? Motor wont run right
Im not sure if this is the right forum but ive got a question open for anyone who can help.
Someone broke in my car last week and stole my vafc and now my car will bearly idle. and when i try to drive it the motor sounds like its sputtering or maby even mis-firing. I have no idea what is wrong i have made sure the wires aren't touching each other. I was just wondering if someone could give me a quick fix until I can get my new controller in so I can at least drive my car and get a new window.
I have a 90 crx si with a jdm b16 swap just so you know what motor and ecu and everything.
if anyone could help i would appreciate it.
thanks
Old Nov 2, 2004 | 01:48 PM
22boost's Avatar
Default Re: VAFC? Motor wont run right (Brett_Hicks)
did you reconnect the wires you cut for the vafc? like the MAP?
Old Nov 2, 2004 | 03:18 PM
Default Re: VAFC? Motor wont run right (93dxkid)
the wires were just tapped into the lines they didnt use a specific harness to connect it into the ecu
Old Nov 2, 2004 | 05:45 PM
22boost's Avatar
i haven't had experience with the vafc...but i know with the safc you cut the MAP sensor wire and then connect the 'in' and 'out' through the SAFC...i would asume the same with the VAFC...and probably the same with the vtec....not sure though
Old Nov 3, 2004 | 09:14 AM
anyone happen to know which wire the map sensor wire would be?
Mr. Vapor
Apr 26, 2005 10:39 AM
bill clinton jr.
Jan 15, 2005 02:27 PM
iam7head
Jul 14, 2003 04:26 PM
2000blacksi
Aug 27, 2002 10:28 AM
IgniteTeg
May 1, 2002 03:57 AM
