vafc installation....
Old Apr 25, 2003 | 02:14 PM
Ludeboi's Avatar
Default vafc installation....
currently, my car is almost stock...but i juss wanted to hook up the vafc myself, just as a display unit, what wires do i hook up?
Old Apr 25, 2003 | 02:42 PM
sslude's Avatar
Default Re: vafc installation.... (Ludeboi)
go to their website, shows you how to do it.
Old Apr 25, 2003 | 02:44 PM
Ludeboi's Avatar
Default Re: vafc installation.... (sslude)
which wires do i leave disconnected?
Old Apr 25, 2003 | 02:47 PM
ScottEK's Avatar
Do you:
A) Just want it to turn on, If so hook up the red and yellow powers and the two grounds. (Wire colors might be wrong)
B) Want it to work but not effect car, Hook up everything exactly like how they say to, go to ETC, and I think initialization to reset the unit. Then go through all the setup steps but don't mess with fuel curves or anything. If you put your VTEC x-over point at where your factory one is and not mess with the throttle maps I believe you'll just be running the stock ECU, someone correct me if this is wrong.
Old Apr 25, 2003 | 02:52 PM
Ludeboi's Avatar
Default Re: vafc installation.... (beta13)
i juss want to be a little display unit, that shows the rpm, etc
Old Apr 25, 2003 | 02:57 PM
ScottEK's Avatar
See B.
Old Apr 25, 2003 | 03:30 PM
wm5holla's Avatar
help the guy out. HT.com needs 2 stp flmain
Old Apr 25, 2003 | 03:39 PM
Ludeboi's Avatar
i want to tap into the least ecu wires as possible..
Old Apr 25, 2003 | 07:26 PM
98civicEX's Avatar
okay, this is what you do...hook upo the ECU completely...set up the VAFC and leave it on stock settings...it's not that hard, and when you're ready to make modifications make adjustments to the VAFC....be sure to read the entire manual on it, and change it to a 4 CYL. http://www.apexi.com
Old Apr 25, 2003 | 08:00 PM
dirtySOHC's's Avatar
Default Re: vafc installation.... (98civicEX)
why wouldnt you wanna hook everything up completly.....pointless. if you read the book entirely you will be able to install it with ease. i am a bit skeptical about wiring things and i got it finished in less than an hour. take your time and always double check the wires and the diagram before splicing.
Old Apr 25, 2003 | 11:17 PM
Ludeboi's Avatar
thanks, will do....i'll keep u guys informed
Old Apr 25, 2003 | 11:27 PM
B00ST2nR's Avatar
solder the wires... using connectors can **** it up.
LKSi
Mar 30, 2007 12:47 PM
ham
Jul 31, 2005 05:51 PM
vaporboy12
Dec 8, 2003 05:36 PM
BRICKHEAD
Dec 2, 2002 06:23 AM
IgniteTeg
May 1, 2002 03:57 AM
