VAFC ? on ground wiring....
Old Mar 7, 2004 | 05:57 PM
X2BOARD's Avatar
Default VAFC ? on ground wiring....
Hey, When putting in an afc, They recommend you wire the 'brown' wire closer to the ecu than the 'black' wire.
Does it matter much on how far apart they are spliced in ? I mean would an inch between the splices/solders be fine ? OR should it be a longer distance ?
X2
Old Mar 7, 2004 | 06:02 PM
IN VTEC's Avatar
Default Re: VAFC ? on ground wiring.... (X2BOARD)
I've got about two inches separating mine.
Old Mar 7, 2004 | 06:16 PM
X2BOARD's Avatar
Default Re: VAFC ? on ground wiring.... (IN VTEC)
2 inches ? Yah... think I have that kinda space.
Did you solder it in ? That's what I plan to do.
Old Mar 7, 2004 | 06:24 PM
IN VTEC's Avatar
Yup. I have a VTEC harness tho.
Old Mar 8, 2004 | 03:34 AM
X2BOARD's Avatar
a vtec harness ?
Old Mar 8, 2004 | 06:33 AM
IN VTEC's Avatar
Field's VTEC controller harness. Snaps in-line b/w the ECU and in-cabin ECU harness with a bunch of leads for the Field's VTEC controller.
Old Mar 8, 2004 | 07:29 AM
X2BOARD's Avatar
damn...wish I had one for the afc...
Old Mar 9, 2004 | 06:32 PM
jrcrx's Avatar
Nope it does not matter how far just as long as the brown wire is closer to the ecu. also dont make the black one to far off!!
(760)doogie
Jun 22, 2008 08:29 PM
GreddyCivic7
Feb 10, 2007 03:35 PM
greebler
May 12, 2003 10:53 AM
YEE*MagicEK20kombobomber
Feb 25, 2003 08:12 PM
iperez
May 2, 2002 05:59 PM
