V-AFC question
Im installing a v-afc in my car in the morning and i have a quick question. Im running a second gen obd-1 b16a in a 93 civic, do i use the h7-a wiring diagram for the 2000si civic, or the h2-a diagram for the integra? Does my ecu have a vtm signal?
I highly doubt you're running an OBD2b jumper (99-2000 Si/P2T ECU) in your car so only if you are use H7-a... If you are running an OBD1 ECU as I suspect just use H3-a... Your ECU will have a VTM input so long as it is a VTEC ECU, and the pinout will always be D6 (OBD1)... Everything else is pretty straight foreward but if you need anything let me know, Peace
civicfanman
Apr 7, 2005 07:39 AM
