V-AFC question
Old Aug 11, 2003 | 08:13 PM
Soled Out's Avatar
Default V-AFC question
Im installing a v-afc in my car in the morning and i have a quick question. Im running a second gen obd-1 b16a in a 93 civic, do i use the h7-a wiring diagram for the 2000si civic, or the h2-a diagram for the integra? Does my ecu have a vtm signal?
Old Aug 11, 2003 | 08:45 PM
Soled Out's Avatar
Default Re: V-AFC question (Gray EG)
anyone?
Old Aug 11, 2003 | 09:41 PM
Kataku2K3's Avatar
I highly doubt you're running an OBD2b jumper (99-2000 Si/P2T ECU) in your car so only if you are use H7-a... If you are running an OBD1 ECU as I suspect just use H3-a... Your ECU will have a VTM input so long as it is a VTEC ECU, and the pinout will always be D6 (OBD1)... Everything else is pretty straight foreward but if you need anything let me know, Peace
parki59
Engine Management and Tuning
Jul 15, 2010 02:09 PM
gonmaro
Mar 20, 2009 12:42 PM
vw eater
Sep 15, 2005 01:31 AM
civicfanman
Apr 7, 2005 07:39 AM
cu_jarrett
Apr 20, 2004 02:05 PM
